Thread: Lost passenger puddle light cable inside the door
Results 1 to 10 of 15
  1. Lost passenger puddle light cable inside the door
    Mar 2008
    11 Post(s)
    After a successful change of LED numberplate lights, decided to change the puddle lights under the door
    Drivers side door was fine but passenger side door had much less slack on the cable. What this means is it jutted out of my hand as I unclipped the old holder ... bye bye cable.
    It's gone somewhere inside the door but with such a tight opening, I just can't get to it and since my drive, I can't feel it either.
    Any advice would be much appreciated in trying to get it back out.
    If it means taking the door card off...do let me know but also how the heck I do this. I only found one screw at the bottom of the door card
    Thanks!
  2. Re: Lost passenger puddle light cable inside the door
    Mar 2008
    11 Post(s)
    Panic over - after a weekend of trying to shove my finger in that hole (perfectly clean thread!), I found a wire hanger which freed the cable. Looks like it had dropped under a bit of plastic which in-turn held it down.
    Cable was still very short but managed just enough to plug it into the new holder
    Let there be light!
    Now onto the rear doors - amazing how bright the ground is ... even in daytime light
  3. Re: Lost passenger puddle light cable inside the door
    46 Post(s)
    Are the puddle lights not LED anyway?
  4. Re: Lost passenger puddle light cable inside the door
    Sep 2011
    Lurking over a keyboard ...
    On mine puddles are bulb, the inside footwells are led, ambient lighting in door trim is led and I think the red exit lights are bulb AFAIK they came like that
  5. Re: Lost passenger puddle light cable inside the door
    46 Post(s)
    Quote Originally Posted by gupsterg View Post
    I'm pretty sure my puddles are LED, as as are door strips and footwell lights and the door lights is a bulb as you say
  6. Re: Lost passenger puddle light cable inside the door
    Mar 2008
    Herts
    Mine came this way, LED in the mirrors externally i think?
  7. Re: Lost passenger puddle light cable inside the door
    Sep 2011
    Quote Originally Posted by fieldy View Post
    +1 , yep mine also got LED on black mirror trim underneath...
    46 Post(s)
    I'm an idiot - I was mistaking the puddle lights for the under mirror led ... Whoops!
    But yes, puddle is normal bulb and under mirror is led
  9. Re: Lost passenger puddle light cable inside the door
    Sep 2011
    puddle lights for the under mirror led ....
    I think I've seen them described as that even somewhere in brochure or something... but they do not even reach floor
    They do look nice when you do the coming home/leaving home light thing, creating that shine on the door skin
    Could be they like that for me as mine are folded will have to check unfolded ... what they like on yours Chris?
    Wish they'd added the LED's also to the door handles like the BMW's (ahhh I just committed blasphemy )
    46 Post(s)
    The new c7 has door handle lights and I'll let you off with that as I like the feature too!
  1. Please Help Puddle in passenger rear footwell
    By BIGBADBORA in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2011, 09:16 PM
  2. Passat estate- puddle in passenger footwell
    By jenny35 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-01-2011, 11:20 PM
  3. Please Help Hug puddle of water in front passenger footwell
    By ajb1978 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 06-01-2009, 07:31 PM
  4. Passenger door will not open from inside or outside
    By Cronus in forum Early Passat Forum - Pre 97
    Last Post: 07-10-2008, 11:00 AM
  5. Front Passenger Door will not open using inside handle
    By silentbazz in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2008, 01:38 PM
