Thread: Headlight Switch replacement...
Results 1 to 10 of 10
  1. Headlight Switch replacement...
    Dec 2009
    Hi all,
    I recently bought a 2nd hand main headlight switch for my B6 MY2002. The original was badly scratched fingernail styley and so decided to replace it. I found one on good old fleabay and when it arrived it was in perfect nick...however after fitting it the headlights stay permanently on. In fact just plugging it in illuminates the side lights and that is with the key in the ignition but off and with the key out. When you turn the key it then turns the main beam headlights on...all of this is with the switch set to "0" or "off" turning the switch changes nothing as they're already on...
    I've already checked the soft coding and it is set to the same as the original switch which is 00001 ie everything disabled and region set to "rest of world"...
    Original part number: 8E0 941 531 01K
    New part number: 8E0 941 531 A 01A
    Does anyone have any suggestions as i'm borderline going out of my mind on this one!?
    Thanks for all your help...
    Keith
  2. Re: Headlight Switch replacement...
    Jan 2009
    Bournemouth
    I also bought a new one for the same reason and mine is doing the same!
  3. Re: Headlight Switch replacement...
    May 2007
    knee deep in clunge
    14 Post(s)
    wrong switch
    standard switch without auto lights 8e0 941 531 or drl
    check your part numbers and post them on here to check
    8E0 941 531 A 01A should be 8E0 941 531 A = with headlight activation so only supported by highline central electrics no good for you as you have lowline
    Southern County Softy
    20 Post(s)
    I might take the switch off you.
    Post a pic.
    follow me on twitter...kiteaudi...
    A4 2.5 tdi QS (mapped)
  5. Re: Headlight Switch replacement...
    Dec 2009
    Quote Originally Posted by kite View Post
    Post a pic.
    Hi kite. If you PM me your email address I'll send over a picture ASAP...
    Hi a8, basically it won't and will never work right? Simply enough I need an 8e0 941 531 with no additional lettering after this, or is there other ones that will suffice?
    I've been hunting for a decent one for 8 weeks now and finally find one and get stitched up :-(
    20 Post(s)
    PM'ed
  7. Re: Headlight Switch replacement...
    Nov 2008
    N/A
    8E0 941 531 is the only one that will work. Suffix A is for auto headlights (as a8_tech said)
    20 Post(s)
    I have photo of the switch.it has no auto position
  9. Re: Headlight Switch replacement...
    Jun 2006
    Cardiff
    The headlight switch does come apart so you could just swap the facia over & keep your original rear section.
    https://www.vwaudiforum.co.uk/forum/s...h-illumination
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  10. Re: Headlight Switch replacement...
    Jan 2009
    Bournemouth
    Quote Originally Posted by pauldazzle View Post
    That is what i have done
  1. Headlight switch
    By rizday in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-05-2012, 02:11 PM
  2. Question B6 headlight switch
    By domo73@tiscali. in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-12-2011, 07:20 PM
  3. headlight switch.
    By ckrisrok in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-12-2010, 07:53 PM
  4. a4 headlight switch
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2009, 09:15 PM
  5. Headlight Switch
    By squid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-01-2009, 08:25 PM
