Thread: Armrest / Phone prep dismantling
Results 1 to 10 of 20
  1. Armrest / Phone prep dismantling
    Apr 2012
    United Kingdom
    I've just recently purchased a 2006 2.7tdi which has bluetooth and phone prep in the armrest. I want a way to charge my Samsung Galaxy s2 and had planned on using the Samsung Car mount and installing it in the armrest and running a female usb connector into the armrest so I can easy change the charging connector/dock when I change phones. I've managed to remove the armrest but cant figure out how to either remove the phone prep or dismantle the arm rest to run a usb cable into the armrest itself.. .does anybody have any ideas/help?
  2. Re: Armrest / Phone prep dismantling
    Sep 2011
    Lurking over a keyboard ...
    Hi, so are you looking for wiring diagram/pin out to make usb have positive and ground dc from existing wiring going to phone prep connectors in armrest?
  3. Re: Armrest / Phone prep dismantling
    Apr 2012
    United Kingdom
    Quote Originally Posted by gupsterg View Post
    Well I had planned to leave the existing wiring alone and just tap into the cigarette lighter socket as a power source. I'm actually looking for a way to feed a usb cable from behind the centre console rear vent into the armrest. I can remove the armrest but I cant figure out how it comes apart to feed a cable into it.
  4. Re: Armrest / Phone prep dismantling
    Sep 2011
    Gotta sleep now had busy day, will look in service guide to see exploded view of armrest tomorrow if no else reply first.
    I think tapping into 12v cigarette lighter is best route to keep wiring phone prep intact.. like your thinking gives me ideas!!
  5. Re: Armrest / Phone prep dismantling
    Apr 2012
    United Kingdom
    Thanks! much appreciated
  6. Cool Re: Armrest / Phone prep dismantling
    Sep 2011
    Use suitable trim removal tool/plastic wedge to prise rear edge of storage compartment.
    Lift storage compartment including handle support for centre armrest.
    To remove lower trim off armrest there is a gasket around metal mounting point remove that, then un-clip.
    There are two screws on underside of storage compartment tray which hold that mounting for phone in place, I would unplug electrical connections then mod armrest.
    Be careful as these bits of plastic are not cheap, repair set for front catch £18, storage compartment about £80, repair set for lower trim is £20.
    Hope this helps, now when I get time I can finally have my HTC and any other phone with universal phone holder & USB recharge point in the armrest, thanks to your most helpful idea ...
  7. Re: Armrest / Phone prep dismantling
    Oct 2011
    Barnsley, South Yorkshire
    Just a heads up for us Galaxy S2 owners..
    Recently upgraded to ICS 4.0.3, did a full format and had to resync the bluetooth with the car..
    Found it wouldn't use RSAP, (Remote Sim Access Profile) and would only connect via hands free mode.. this wastes battery, and doesn't use the cars aerial.
    After searching, I found out that RSAP has been dropped in ICS, so until they sort it out, I have downgraded back to Gingerbread..
    So, if you are thinking of going to ICS, you may wish to wait a while.
    John
  8. Re: Armrest / Phone prep dismantling
    Apr 2012
    United Kingdom
    Thanks Gup, those pics are fantastic, much appreciated! I'll upload pics once I've tackled it (just waiting for a hardwireable usb cable to arrive). I cant reply to pm's as yet so I'll just reply here, the topic change is a great idea/fine by me
    Also Einstein, as far as Im aware, phones connected via bluetooth dont use the cars aerial anyway, only ones using the phone prep do? ( I may be wrong!) but I suggest you ditch the official 4.0.3 rom as its pretty awful, root your galaxy and go with Cyanogen Mod 9, unlike the Samsung rom its close to the stock ICS rom so it looks much nicer and has far fewer bugs/better performance and battery life. They also updated it every day or 2.
  9. Re: Armrest / Phone prep dismantling
    Sep 2011
    No prob mate, happy to help and great idea.
    Gonna do mod to mine and great thing is that all people can do this! All have 12v electrics plus already fused!
  10. Re: Armrest / Phone prep dismantling
    46 Post(s)
    Phones that use RSAP use the cars aerial for better signal stength and less battery use on the phone.
    Phones can either be conncted (handset dependant) via Handsfree mode (just transfers the sound to the car, iPhones) or RSAP where the sim card is used direct from the phone and all features are used via the car
    Let me know what you want the thread changed to and it can be done
  1. Question Phone Prep
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-09-2011, 02:10 PM
  2. A4 SE phone prep.
    By liftmanina4 in forum Chat - Anything with wheels
    Last Post: 29-09-2010, 07:01 PM
  3. Phone Prep
    By pscocoa in forum Phaeton
    Last Post: 12-05-2010, 02:26 AM
  4. Phone Prep
    By firelogic in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-07-2008, 09:04 PM
  5. Armrest mounted Ipod prep v. multimedia+USB
    By colinandlesley@ in forum New Member Introductions
    Last Post: 21-03-2008, 09:48 PM
