Thread: Rubbing/ screeching noise when steering wheel turned
  1. Rubbing/ screeching noise when steering wheel turned
    Mar 2010
    London
    Whenever I turn the steering wheel hard to the left or right there is a rubbing/ screeching sound that comes from the wheels. This happens when the car is stationary. Would anyone have any suggestions as to what is causing this?
  2. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2008
    High Wycombe
    Coming from the front wheels? Is it just the tyres rubbing on the tarmac? Does it do it if the car is rolling very slowly forward / backwards?
    Is it as the steering wheel is turning, or when you get to full lock and the power steering pump starts whining? If it's the power steering pump screeching, check if the drive belt is flapping when on full lock - if it is, then it's likely to be a fault with the one way pulley on the alternator.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2010
    London
    Thanks for your reply.
    It's when the car is not moving and when the steering wheel is turned fully but held in position. Seems similar to this - https://www.vwaudiforum.co.uk/forum/s...reeching-noise
    Does anyone know whether this is also relevant to Audis?
  4. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2008
    High Wycombe
    Yes, it sounds like it's the power steering pump on full lock. Does the noise stop if you turn the steering wheel back by about an inch?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2010
    London
    Yes, it does stop
  6. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2008
    High Wycombe
    If it's a loud whirring noise, then it's probably normal, but if it's screeching, then it's a problem. Have an assistant hold the steering wheel at full lock, and if the drive belt starts flapping, then see about getting the alternator pulley replaced.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Rubbing/ screeching noise when steering wheel turned
    Mar 2010
    London
    Hi NickPicks
    You're spot on - I had the alternator pulley replaced and that resolved the problem.
    Thanks for your help everyone.
    _sc_
  1. Question screeching noise
    By carl55 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2012, 12:05 AM
  2. Please Help Steering Wheel Rubbing on Cowling
    By nc35 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-07-2010, 07:26 AM
  3. Question Strange sound when the steering wheel is turned to the right
    By milanfaca in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-06-2009, 08:27 AM
  4. Please Help Clunking noise from front left when wheel turned in to right
    By 30miles in forum Beetle 2000-
    Last Post: 17-05-2009, 03:20 PM
  5. Screeching noise
    By gazboxer in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2008, 04:05 PM
