Thread: A6 C7 VCDS Tricks
Page 18 of 90 FirstFirst ... 816171819202868 ... LastLast
Results 171 to 180 of 897
  1. Re: A6 C7 VCDS Tricks
    46 Post(s)
    MY14 might be compatible, the car I tested it on was a 63 plate SE with Colour DIS and HDD nav.
  2. Re: A6 C7 VCDS Tricks
    Stratford upon Avon UK
    36 Post(s)
    So thanks for the info Chris.
    Splash and I tried to set up a few things on my allroad last night and here are the results - these are using the guidance off the first post.
    - Lap timer / Oil temp / Boost works fine. Oil temp is the item of interest so pleased to be able to see that.- Battery meter, we tried to enable but I still cannot find it in the MMI- Passenger door mirror dip on reverse works as expected. As has been noted if you turn the adjuster knob away from the left mirror setting it does not dip (and if dipped returns to regular position)- Close boot with key does not seem to work
    A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
  3. Re: A6 C7 VCDS Tricks
    Apr 2014
    Dublin, Ireland
    I have had two C7s and neither had this option for the parking brake, has this been confirmed on the C7?
    15. Enable auto handbrake when shift into P
    [Select]
    [53 - Parking Brake]
    [Security Access - 16]
    Code displayed to me was - 78713
    [Adaption - 10]
    [Select]
    "Shift P to EPB"
    Set to Activated
    [Do It!]
    Just curious,
    Shane
  4. Re: A6 C7 VCDS Tricks
    46 Post(s)
    Quote Originally Posted by shaneypoopers View Post
    [Select]
    [Adaption - 10]
    [Select]
    "Shift P to EPB"
    Set to Activated
    [Do It!]
    Just curious,
    Shane
    Yep, that was me added that. Worked perfectly on a MY2014 63 plate.
    The EPB module as below
    Code:
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000884018
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 2C537C7E47CB1B7E17F-8079
    No fault code found.
  5. Re: A6 C7 VCDS Tricks
    Apr 2014
    Dublin, Ireland
    Hey Chris,
    Looks like your Park Brake has a newer software version so maybe thats the reason for it. Mine is a 12 plate so perhaps they have changed it.
    Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
    Component: EPB-4 H03 0012
    Revision: -------- Serial number: 00000000316756
    ASAM Dataset: EV_ParkiBrake 001022
    ROD: EV_ParkiBrake.rod
    Not a big deal but would be nice if it came on when in 'P'.
    Thanks,
    Shane
  6. Re: A6 C7 VCDS Tricks
    Apr 2014
    Dublin, Ireland
    On another topic, I was nosing around in the hidden menu and noticed options for enabling the Rest Recommendation and Tilt Angle Display systems. I can enable the options in the MMI but they are greyed out as I would imagine I need to enable something with VCDS. Does anyone have either of these systems enabled? If so could you post a an autoscan so I can compare the differences and see if this is something that can be switched on.
    Shane
  7. Re: A6 C7 VCDS Tricks
    36 Post(s)
    Both are enabled in my allroad - although I switch of the rest nag function in MMI. I've included the dump of the scan below.
    The issue MAY be that your chassis type is 4H (I think) whereas allroad is 4G
    It may be that for tilt angle you do not have all of the required sensors, I suspect you may have fore/aft angle for the clever cruise control / gearbox stuff but not 'yaw' (side to side)... unless it is a single sensor unit (which in these days of mobile phones and embedded accelerometers etc. would be the logical thing to do).
    There is one error logged (which seems to be common - Splash has it and I saw another post where it was also present) - 5F-Information Electr. -- Status: Malfunction 0010
    Reading the detail of the log I THINK it relates to a failed opening of the MMI pop-up screen... Anyone else seeing this?
    Monday,14,July,2014,20:05:23:52225
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 3B 42 44 46 52 53 55
    56 5F 62 6D 72 85 A9 C0
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 01: Engine (J623-CGQB) Labels: None
    Part No SW: 4G0 907 589 C HW: 4G0 907 589
    Component: 3.0BTD EDC17 H25 0001
    Revision: 57H25---
    Coding: 322A403225260B020000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM30BTD0114G0907589C 001001
    ROD: EV_ECM30BTD0114G0907589C.rod
    VCID: 346C67889FF76EBE4FF-8061
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
    Part No SW: 4G0 927 158 L HW: 0BK 927 156 AM
    Component: 0BK 30RTDIRdW H16 1003
    Revision: --H16---
    Coding: 000001
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002022
    ROD: EV_TCMAL551211_AU57.rod
    VCID: 377650848E8185A66AD-8062
    Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
    Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
    Component: ESP PREMIUM H09 0450
    Revision: -------- Serial number: --------------
    Coding: 49A7DF0592E5FBA0DB00
    ASAM Dataset: EV_ESPPremiAU57X 004039
    ROD: EV_ESPPremiAU57X.rod
    VCID: 3A7049B0BD9398CE953-806F
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
    Component: BCM2 2.0 H33 0433
    Revision: 00002001
    Coding: 01B93046000000000000
    VCID: 77F69084C60145A6AAD-8022
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
    Component: KLIMA 4 ZONEN H13 0087
    Serial number: 15051300041146
    Coding: 362200B825
    ASAM Dataset: EV_AirCondiComfoUDS 002040
    ROD: EV_AirCondiComfoUDS.rod
    VCID: 62C0D1D07583B00EED3-8037
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
    Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0130
    Revision: 20012002 Serial number: 00000001562086
    Coding: 0200201050B49FE0498100C300001908CF9D47082F08020100 0008406100
    VCID: 6ED8B5E0B95B046E79B-803B
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A
    Component: WWS57X 130503 H36 0080
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
    Component: G397_RLFS H06 0002
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
    Component: E1 - LDS H07 0044
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Address 10: Park/Steer Assist (J791) Labels: None
    Part No SW: 4H0 919 475 AB HW: 4H0 919 475 E
    Component: PARKHILFE PLA H06 0060
    Revision: -------- Serial number: 56231313602635
    Coding: 98130C
    ASAM Dataset: EV_EPHVA2CAU57X0000 002012
    ROD: EV_EPHVA2CAU57X0000.rod
    VCID: 72E0A190A563208E9D3-8027
    Address 15: Airbags (J234) Labels: None
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H43 0040
    Revision: -------- Serial number: 003JG00D8MVQ
    Coding: 3032343631334E303537554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_AU57.rod
    VCID: 36685D80898B7CAE71B-8063
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB401050GSAD8C0
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB400E50G78FQ32
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515JRB400M50IC2E0FY
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525JRB400O50I40B92K
    Crash sensor for front airbag; driver side:
    Serial number: 3554VRB401A50F9CEHOP
    Crash sensor for front airbag; passenger side:
    Serial number: 3564VRB400850HHQLH3X
    Address 16: Steering wheel (J527) Labels: None
    Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
    Component: Lenks.Modul H05 0201
    Revision: 00000000 Serial number: 20130520000070
    Coding: 000035
    VCID: 30646B9863EF529E2B7-8065
    Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
    Component: E221 - MFL H08 0010
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G9 920 950 N HW: 4G9 920 950 N
    Component: TDieGb Nv H80 0618
    Revision: 30131230 Serial number: 658130513596020
    Coding: 33A621081B412600010600
    ASAM Dataset: EV_RBD4K 004048
    ROD: EV_RBD4K.rod
    VCID: 3B7E4CB4B2A9A1C68E5-806E
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
    Component: J533--Gateway H12 0037
    Revision: -------- Serial number: 00000000938207
    Coding: 00CD077D00
    ASAM Dataset: EV_GatewPkoUDS 001018
    ROD: EV_GatewPkoUDS.rod
    VCID: 71E2AE9CA0651B96649-8024
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 1271520503
    Voltage stabilizer:
    Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
    Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
    Component: KLIMA FOND H07 0087
    Serial number: 17051300040905
    Coding: 22
    ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
    ROD: EV_ClimaContrUnitRearUDS.rod
    Address 34: Level Control (J197) Labels: None
    Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
    Component: LUFE-DAEMPFER H18 0782
    Coding: 008000
    ASAM Dataset: EV_AirSuspe 003024
    ROD: EV_AirSuspe_AU57.rod
    VCID: 2E5875E071DB446E39B-807B
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
    Component: SARA 6D H02 0056
    Revision: -------- Serial number: EJ1BPA8203K3G3
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2_AU57.rod
    Address 42: Door Elect, Driver (J386) Labels: None
    Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
    Component: TSG FA H03 0507
    Coding: 011F16004001620002080002
    VCID: 47962044F661F5261AD-8012
    Address 44: Steering Assist (J500) Labels: None
    Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
    Component: RCEPS H36 0010
    Revision: 00001000 Serial number: 0015496903
    Coding: 101100010000
    ASAM Dataset: EV_RCEPS 009008
    ROD: EV_RCEPS.rod
    VCID: 3260619065E3608E5D3-8067
    Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0307206873
    Coding: 013B0622A0B930008320090400010F47000000000000000000 0000000000
    Subsystem 1 - Part No: 4G0 951 177
    Component: DWA-Sensor H01 0010
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 52: Door Elect, Pass. (J387) Labels: None
    Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
    Component: TSG BF H03 0507
    VCID: 46882D40F16BEC2EE1B-8013
    Revision: -------- Serial number: 00000000695605
    VCID: 2C5C7FE847C7367E17F-8079
    Address 55: Xenon Range (J431) Labels: 4H4-907-357.clb
    Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
    Component: ....AFS13.... H01 0020
    Serial number: 130517-0004-032
    Coding: 11226F33F918EB00
    ASAM Dataset: EV_AdvanFrontSyste 005001
    ROD: EV_AdvanFrontSyste.rod
    Left Headlamp Power Output Stage:
    H02 0010
    Right Headlamp Power Output Stage:
    H02 0010
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 061 L HW: 4G0 035 061
    Component: Radio U DAB H60 0133
    Revision: AB001007 Serial number: 109E20D7681289
    Coding: 010103020100000001
    VCID: 26488DC0512B0C2EC1B-8073
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 666 K HW: 4G0 035 666 H
    Component: H-BN-EU H51 0732
    Revision: -------- Serial number: 189E-0DB000805
    Coding: 080101050003F1ED05808B3E00000003E00001020200000000
    Subsystem 1 - Part No: 8R0 060 884 BC
    Component: EUR 2013/2014 1603
    Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
    Component: DU8 C7 SV H43 0021
    Subsystem 3 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
    Component: E380 BDT C7 H11 0204
    Subsystem 4 - Part No: 8R0 060 961 F
    Component: CD-Database 5298
    1 Fault Found:
    03787 - Rotation Mechanism for Display Module Front
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 74
    Mileage: 19891 km
    Time Indication: 0
    Date: 2014.06.08
    Time: 09:55:06
    Freeze Frame:
    Voltage: 11.40 V
    Address 62: Door, Rear Left (J388) Labels: None
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0507
    Coding: 010F14004001620002080002
    VCID: 4992267CE07503560C9-801C
    Address 6D: Trunk Elect. (----) Labels: None
    Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
    Component: HDSG-Modul H03 0143
    Revision: 14003001 Serial number: 129300699
    Coding: 097205C010
    ASAM Dataset: EV_HDSGAu572 001022
    ROD: EV_HDSGAu571_AU57.rod
    VCID: 356A5A8C948D77B6781-8060
    Address 72: Door, Rear Right (J389) Labels: None
    Component: TSG HR H03 0507
    Address 85: On Board Cam. (J852) Labels: None
    Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
    Component: DPC-SG H26 0038
    Revision: -------- Serial number: 262130025421000
    Coding: E4040000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 26488DC0592B0C2EC1B-8073
    Address A9: Struct. Borne Sound (J869) Labels: 4G0-907-159.clb
    Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0005
    Serial number: 130
    ASAM Dataset: EV_SoundActuaGen2AU64X 002005
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 2B5E7CF442C931461E5-807E
    Address C0: Act. for Ext. Noise (J943) Labels: None
    Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
    Component: SAS-GEN 2 AGA H09 0004
    Serial number: 130327200048
    ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
    ROD: EV_ActuaForExterNoiseUDS.rod
    VCID: 244C97C82F17FE3EDFF-8071
  8. Re: A6 C7 VCDS Tricks
    Apr 2014
    Dublin, Ireland
    Cool, I'll have a pour through it over the weekend and see if anything jumps out at me.
  9. Re: A6 C7 VCDS Tricks
    Apr 2014
    Dublin, Ireland
    Had a look at coding that in by going through the coding differences one at a time but didn't get the tilt angle or rest recommendation to work.
    I did get a few other things to change like saloon or avant in the MMI display but that can be altered through the green menu and not sure why you would change it anyway.
    I'm guessing additional sensors are required for tilt angle and rest recommendation.
  10. Re: A6 C7 VCDS Tricks
    Apr 2014
    Norton, Daresbury UK
    Hi Guys I live in Daresbury near Runcorn and work in Warrington so happy to travel surrounding areas. My car gets delivered in September and would like the following enabled
    1. Enabling Gauge Test/Needle Sweep
    3. Kerb lighting
    8. Passenger door mirror dip on selecting reverse.
    12. Modifying the High Beam Assist speed threshold
    18. Disable DRL dim on turn signal
    Any help would be appreciated
    Paul
  1. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  2. mark 5 tips and tricks
    By m24man786 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2010, 09:58 AM
  3. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  4. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
  5. tips and tricks for golf mk5's
    By Ben in forum Golf MK5 - 2004 - 2009
    Last Post: 17-08-2008, 09:25 PM
