Thread: USB / Cigarette Lighter adapter question
Results 1 to 10 of 13
  1. USB / Cigarette Lighter adapter question
    Mar 2009
    York
    I have just purchased a low-profile belkin USB charger that plugs into the cig lighter at the front. It is very low profile so the cover is able to close with it plugged in.
    However I'd like to know whether I risk draining the battery this way, even when nothing is plugged in... there is a small red LED on top showing it is connected. How much power will this drain if it is left in overnight? I won't be charging anything on it overnight, just leaving it plugged in (and yes, these cigarette light sockets don't need keys in the ignition to work either!).
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: USB / Cigarette Lighter adapter question
    Norfolk
    If it's a single red LED, the battery won't notice the current drain. It's possible but unlikely that it will stop the can-bus going to sleep. If it does that, the battery will go flat.
  3. Re: USB / Cigarette Lighter adapter question
    Dec 2009
    14 Post(s)
    I would say unplug it. I always unplug my sat nav. Same kinda thing. Has a small led on the plug. Dont really fancy risking a flat battery.
    Also I think mine is the original battery 6yrs old.
  4. Re: USB / Cigarette Lighter adapter question
    Mar 2009
    Sleaford, Lincs, UK
    My sockets don't work with the key out!
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  5. Re: USB / Cigarette Lighter adapter question
    46 Post(s)
    I'd say leave it in, I leave my phone charger plugged in all the time and it doesn't seem to affect the battery.
    Although if the car is sitting for a couple of days then I would take it out, just incase
  6. Re: USB / Cigarette Lighter adapter question
    Mine still lights an LED even when key is out. 06 tdi sport
  7. Re: USB / Cigarette Lighter adapter question
    Dec 2010
    Renfrewshire, Scotland
    Same as Tomboy - when I pull the key out the power is cut to my front power socket.
  8. Re: USB / Cigarette Lighter adapter question
    Feb 2012
    Exeter UK
    Same here, ignition off, no power to the front (or rear) socket ... Dec 2008 140 tdi Estate.
    Guess this is the safe option with canbus, not letting the possibility of something "meaty" being left "on charge" overnight etc. But frustrating in other ways!
  9. Re: USB / Cigarette Lighter adapter question
    Jul 2011
    Quote Originally Posted by gingernut352000 View Post
    Not so sure about later models, but I was under the impression that ALL the power sockets (front, rear and boot, where fitted) in ALL Passats of that age were dead without the ignition on.
    Not one of those LEDs that stays on for a while after the power is interrupted by any chance?
    2014 Passat Executive estate, 1.6 TDi, 130,000 miles
  10. Re: USB / Cigarette Lighter adapter question
    Halifax , Yorkshire
    Quote Originally Posted by ToMBoY_C View Post
    Mine also goes off when the ignition is switched off .Very annoying when you have the sat nav plugged in and have to leave the car for a few minutes.
    2.0 TDI Executive Saloon 64 Plate 12.5K miles
  1. Cigarette Lighter.
    By nbharatia in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2010, 07:54 PM
  2. Cigarette Lighter
    By Haddas in forum Golf MK3 - 1993 - 1999
    Last Post: 11-02-2009, 02:12 PM
  3. Cigarette Lighter
    By macmillions in forum Golf MK2 - 1984 - 1992
    Last Post: 26-01-2009, 09:20 PM
  4. Golf MK5 Cigarette Lighter Question
    By faruq in forum Golf MK5 - 2004 - 2009
    Last Post: 26-10-2008, 09:15 PM
  5. USB adapter
    By barload in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-01-2008, 08:59 PM
