Thread: Please Help A3 Turns off while idling :'(
Results 1 to 10 of 10
  1. Please Help A3 Turns off while idling :'(
    Apr 2012
    London UK
    HI! guys im new to the forum so im not sure if i am posting in the right place
    i have a audi a3 X reg Auto
    the car drives fine no problems while driving
    but when i am at a traffic light and idling the car turns off it self and doesnt start again
    the only way to start again is by jump starting
    can someone please advise me on what the problem could be??
    the battery is quite new changed it in 2011
  2. Re: Please Help A3 Turns off while idling :'(
    Pembrokeshire
    22 Post(s)
    when you say the car turns itself off i presume you mean it stalls and the dash lights (charge, oil pressure ) come on. then it wont start, does it crank over or not, does anything happen ?
    welcome aboard as well.
  3. Re: Please Help A3 Turns off while idling :'(
    Apr 2012
    London UK
    yeah it stalls
    the lights come on and go off as if the battery is fully dead but its not
    it doesnt crank over
    the only way of getting it to start is by jump starting
  4. Re: Please Help A3 Turns off while idling :'(
    Pembrokeshire
    22 Post(s)
    ok, so from home before a journey, does it start normally without a jump ?
  5. Re: Please Help A3 Turns off while idling :'(
    Apr 2012
    London UK
    nope il have to jump start it
    only starts normally without a start if the car is off for longer than 5min
    im not a rich guy or anything i cant really afford to go garages and get ripped off etc..
    Oct 2010
    Here And There
    Get yourself a good garage and you wont get "ripped off"
    As far as your car problems are though, check your battery with a tester, check your alternator charging rate with a multi meter, check your earth wires and check your wiring to and from the alternator. If you are unsure how to do this, your local garage will probably do it for very little expense and give you a quote
  7. Re: Please Help A3 Turns off while idling :'(
    Apr 2012
    London UK
    thanks A4 LAD il try that
    hope others can rub some light on this too
  8. Re: Please Help A3 Turns off while idling :'(
    Mar 2008
    High Wycombe
    From your posts, I'm not sure what your problem is. You started with "It stalls", then "It'll only start with a jump start", then "It'll only start without a jump if it's off for longer than 5 mins".
    So, From "It stalls", I'd have suggested cleaning the throttle body, or the idle stabilising valve (If it's got one - you need to tell us what type of engine it is (there's a 3 digit code on a sticker in the spare wheel well, it'll be somethign like AGN). A fault code read would be a good idea to see if the engine management can tell us anything helpful (This'll cost around £30 from a decent independant garage)
    It also sounds like you have starting problems. If it doesn't then crank over, it's either that the battery is flat, or there's a problem with getting electric to the starter motor, so as A4Lad said, check the wiring. Halfords will test the battery for you for free with no obligation to buy a new one from them.
    Does it start OK when jumping from another vehicle - this would make me think that the battery is flat (so it's then either a duff battery or the alternator is not charging). Use a voltmeter to see the battery voltage when the engine is off (ahould be about 12 volts) and when it's running (should be around 14 volts).
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Please Help A3 Turns off while idling :'(
    Apr 2012
    London UK
    @NickPicks the car will turn off e.g. stall while idling... the car at this stay will only turn on from a jump start... at this stage if i turn the key there is no crank.
    if the car if parked up and off for longer then 5/10min it will only start from a jump start and the only way i can enter the car if by unlocking the car manually
    the car starts fine when starting from another car or from a jump pack
    i did a fault code checker on the car and no codes where found.
    i will take the car today to halfords to get the battery tested.
    i will let you know soon what type of engine i have
    thanks
  10. Re: Please Help A3 Turns off while idling :'(
    Mar 2008
    High Wycombe
    Well, if it starts from a jump, but won't crank on it's own battery, I'd say that the battery is flat and not taking a charge so it's either:
    - the battery is dead,
    - the alternator is not charging (although then I'd expect the red battery charge light to be on)
    - or possibly both of the above
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Radio turns on by itself
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2012, 04:53 PM
  2. music turns itself on
    Last Post: 13-10-2011, 07:04 AM
  3. Turns over but won't start
    By Steven Alexande in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2008, 12:48 PM
  4. Symphony II turns itself off
    By gtrman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-04-2008, 12:48 PM
  5. Turns over but Not Starting
    By r9mey in forum Beetle 2000-
    Last Post: 26-05-2007, 06:32 PM
