Thread: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
Results 1 to 10 of 13
  1. Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Aug 2008
    I've had the glow plug light flash on and off on my Audi after a few miles on a run with a loss in power (vehicle still drives just flat) once the engine management light has come on however this has been reset and a code of P0299 has been read on a VCDS.
    The car has been checked by another Tech today who comes up with the same code and information along the lines of Turbo Charger under boost, Permanent.
    Any help or advice would be much appreciated please?
    Manny,
  2. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Aug 2008
    Hi I've had some advice one saying it may be Turbo and another saying could be the actuator,
    Any more advice please or to where I could go in and around the Birmingham area please?
  3. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    May 2007
    knee deep in clunge
    14 Post(s)
    Vacuum depletion from collapsed pipe under load, you need a boost reading and vacuum line pressure prior to looking at the turbo as turbo's rarely fail but often replaced
    Again load it up in third gear not at idle due the rev limiter function
    Engine code would be helpful as well IF ITS A 2.0 PD THEN MOST LIKELY TO BE THIS ( vacuum unit of intake manifold ) IF FITTED, THESE UNITS FAIL AND DEPLETE VACUUM
    SEE ATTACHED PHOTO
    Check this
    Check air filter and boost pressure system (seal)
    Check boost pressure sensor and accelerator pedal to make sure values are plausible
    Data block 10: Check boost pressure sensor against the atmospheric pressure sensor of the engine control unit
    (must be less than 50 mbar difference )
    Data block 2: 99-100% has to be achieved in the pedal movement sensor test, when the accelerator is slowly depressed.
    Basic setting, exhaust return valve and boost pressure controller:
    Basic setting 03: Check exhaust return valve
    Basic setting 11: Check boost pressure of exhaust turbocharger. Check vacuum control unit (ATL) with hand vacuum pump
    guide vane setting moves from 100 - 200 mbar, maximum setting is approx. 550 –650 mbar.
    Check synchronisation angle VALVE TIMING !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Data block 4/4: Check setpoint value +/- 3° for synchronisation angle/valve timing. If outside the tolerance, check valve timing and adjust.
    GOOD LUCK
  4. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Aug 2008
    Thanks for the info A8 Tech.
  5. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Aug 2008
    forgot to say it's the latest common rail engine not the PD,
  6. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    May 2007
    knee deep in clunge
    14 Post(s)
    there is a problem with the waste gates on the cr
  7. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by MSS3 View Post
    see your pm box
  8. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Jul 2012
    Scottsdale, AZ
    Any update on the issue. My CEL came on yesterday. I didn't notice a loss of power with the light...the only thing that happened, which might just be a coincidence, is the A/C suddenly blew hot for a few seconds, the CEL came on, then cold air again. Took it to the dealer. When they called they didn't say exactly what the fault code was, but that the car needs a new turbo assembly. My vehicle is an '09 A4 2.0T with 67k miles on it. I'm waiting to hear back, the service tech said he wanted to talk to his GM about it. Any ideas? Is there a known problem with the turbo assembly for this vehicle? Any info would be greatly appreciated! Thanks.
  9. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Colchester,Essex
    My mates Passat 10 plate has the same problem,CR engine and the same code.So waste gates are problems on these are they?I can tell it opens using a vacuum.
  10. Re: Audi 2009 2.0 TDi P0299 fault code saying Turbo charger under boost!! Please help?
    Dec 2009
    kyle Scotland
    Does anyone know if the vain actuator should have fluid in it if so what fluid is it if not then it must have got in when I done the head gasket Thanks in advance David
  1. error P0299 turbo boost. changed everything! help
    By nfegan in forum Golf MK5 - 2004 - 2009
    Last Post: 22-03-2011, 11:03 AM
  2. Please Help P0299 turbo under boost
    By TWENTY_10 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2010, 06:45 PM
  3. Golf MK5 1.9TDI Fault Code P0299 +P0401
    By browser1 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-11-2010, 04:35 PM
  4. Turbo Charger for A4 TDi
    By Kofi H in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2008, 06:34 PM
  5. Tdi 110- Turbo? Fault Code 17958
    By lastyboy in forum Archive posts
    Last Post: 18-10-2007, 10:09 AM
