Thread: Golf SE Atlanta Alloy corrosion - Warranty claim??
Results 1 to 10 of 14
  1. Unhappy Golf SE Atlanta Alloy corrosion - Warranty claim??
    Aug 2008
    Advice requested . . . . . . .
    Cleaning my Atlanta alloy wheels yesterday, as fitted to my 2009 Golf Tsi SE, I noticed some very minor corrosion/pitting appearing on the alloy around the central plastic VW roundel. My Golf is my pride and joy, is washed/waxed regularly, as are the wheels, which have been waxed regularly since new. This is my first experience of a car with alloys - and I have been determined to keep them in tip-top condition. Until now they have all remained immaculate. To some the corrosion I am talking about is trivial but surely that is not the point.
    My question is whether anyone has had experience of warranty claims/dealer dealings with corrosion on alloy wheels?? As mentioned the corrosion is VERY minor but it should still not be happening - and sadly it can only get worse. I covered the area in wax for now. My cars 3yr warranty expires in September so I want to make the dealer aware of this soon - but do I stand a chance of any dealer sympathy??? or a new wheel????????
    Guy
    2.0tdi GT DSG, Pacific Blue, Vienna "Shetland" leather sports seats, Discover Pro Nav system, Colour multifunction display, 2-zone Climate control, steel door sill trims, Rear chrome strip
  2. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    This does happen on VW wheels they call it white worm, vw golf wheels white worm.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  3. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    South London. UK
    Quote Originally Posted by cdgthreesalmons View Post
    My plastic 'roundels' as you call them, suffered from white worm or corrosion and I went to my dealer to get some from the spares. I told them what had happened and why I wanted new ones and they got the works dept. to fit new ones there and then under warranty. That was last year, after two years of ownership.
    Still, you say that your actual wheels are showing signs of corrosion, which is a more serious matter and you should be covered under the 3 year warranty, I would have thought.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  4. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Dec 2010
    Do Atlanta alloys have the diamond cut, highly polished finish? If they do, they can be susceptible to 'whiteworm' corrosion, which happens when lacquered finish lifts and water gets beneath the lacquer and 'creeps' under the lacquered surface. This problem isn't specific to VW; I've seen BMW's and Volvo's with diamond cut, lacquered alloys that are suffering badly from whiteworm.
    VW seem to be fitting alloys with diamond cut / lacquered finish to lots of their current models. Most owners don't seem to have issues getting them changed under warranty (see link below), provided there hasn't been other 'self-inflicted' damage, such as kerbing.
    http://www.golfgtiforum.co.uk/index....495#msg1976495
    If your usual dealer isn't receptive to replacing the corroding wheel(s) under warranty, it'd be worth trying another dealer. Good luck.
    Golf GTD; Carbon Grey, 18" VW Rotary Alloys in Anthracite, Bi-Xenons, RCD510+Dynaudio, Parking Sensors, Luxury Pack and 3 Year Service Plan
  5. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    The diamond machining and clear laquer finish on the Atlanta wheels is not as robust or long lasting as the normal silver colour painted finish as on the earlier models. The diamond cut /clear laquer on my 2009 MK6 model was marked the first time I used a car wash in the first few weeks of ownership. I had been using the same car wash for years with my previous MK4 golf (145K) and with my wife's current Polo (90K) with the ordinary silver paint finish without any problems. Such is the mark of progress ! I am resigned to the fact that I'll probably have to have the MK6 Atlanta wheels re-painted at some time in the future as I doubt whether they will be sufficiently corroded before the 3 year warranty is up to get any VW action to re-paint them.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Feb 2007
    Mine have held up pretty well - car now 30 months old, 45k miles.
    I wax mine 3 times a year, but the main reason they're OK is because i dont use them November through April (winter steel wheels), when there is far more loose stone and grit on the roads. A combination of minute stone chips and road salt will have diamond cut / lacquered alloys corroding in no time at all. Ask anyone with split rim wheels.
    Many years ago Audi advised coating with Vaseline ! - i couldn't quite believe reading that in the owners manual.
    Good luck with a warranty claim - you'll have to have a very understanding (and persuasive with VW) to get a new set of wheels.
    2010 Golf Mk6 TDI105 SE - now departed, replaced with A3 Sportback
  7. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    South London. UK
    Quote Originally Posted by percymon View Post
    In the late '50s/'60' people were often advised to put Vaseline on their Chrome plated bumpers which, unless they were of high quality plating, used to become pitted and looked awful.
  8. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Sep 2009
    cowbridge wales
    No problem with warranty claim. Had corrosion around the centre of the Atlanta alloy about 5mm dia replaced without any hassle
    replaced it without me even asking !
    Golf 1.6 SE Pearl black 2009
  9. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Jul 2007
    I know this is an old thread but other people may find it on searching.
    We've got the diamond cut Atlanta wheels on our Golf Twist and when it was in for service just before 3yrs old I asked them to look at the wheels, which are all showing very early signs of corrosion around the centre caps, with one being much worse. Although I'm absolutely certain the bad one hasn't been physically chipped, it does look like the lacquer has chipped off in several places around the centre hole. Wheels are otherwise in good nick and unkerbed.
    I got completely fobbed off by the dealer, so I contacted VW UK who were initially very supportive, but now are saying leave it another year and we'll work with the dealer to consider goodwill payment towards a refurb. All a bit vague and I don't think diamond cut wheels refurb very easily, or will last long.
  10. Re: Golf SE Atlanta Alloy corrosion - Warranty claim??
    Huddersfield, West Yorkshire.
    Just get them refurbed and stop trying to get something for nothing.
  1. Atlanta wheels corrosion
    By dcdick in forum Golf MK6 - 2009 - 2013
    Last Post: 28-09-2010, 10:58 AM
  2. VW Golf rear alloy wheel corrosion
    By waveydavey888 in forum Wheels and Tyres
    Last Post: 15-09-2009, 05:29 PM
  3. Attention Warning when trying to claim on AA warranty
    By pendle wizard in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-06-2009, 11:38 PM
  4. Making a warranty claim for corrosion, any experience?
    By 54A4Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2008, 07:57 PM
  5. Possible Trim warranty claim ??
    By ChuckH in forum Chat - Anything with wheels
    Last Post: 06-04-2008, 10:56 PM
