Thread: Squealing noise from engine when idling
Results 1 to 10 of 13
  1. Squealing noise from engine when idling
    Feb 2012
    Chester, Wales
    Have a 130 tdi, auto tiptronic box estate.
    Noise only happens on start up and disappears when you pull off.
    Any ideas guys??
  2. Re: Squealing noise from engine when idling
    131 Post(s)
    1973 Post(s)
    Possibly a failing alternator pulley clutch but a little difficult to diagnose without hearing it.
  3. Re: Squealing noise from engine when idling
    Feb 2012
    Chester, Wales
    had a new alternator about 3 weeks ago - not sure if that rules the pulley clutch out?
  4. Re: Squealing noise from engine when idling
    131 Post(s)
    1973 Post(s)
    Depends if the alternator came with a new pulley or not or it came with a solid pulley which I have seen and is wrong.
  5. Re: Squealing noise from engine when idling
    Has the pulley got a black plastic cap on it? if not its solid and that's why you are getting a squeal, it will wreck the tensioner very soon.
    Why did you have a new alternator fitted, did you have "Alternator Workshop" warning, if so this could be caused by the pulley seizing, if only the alternator was changed pulley will still be a problem.
  6. Re: Squealing noise from engine when idling
    131 Post(s)
    1973 Post(s)
    Yes, good point, it looks like this, not open with a visible nut.
  7. Re: Squealing noise from engine when idling
    Feb 2012
    Chester, Wales
    Cheers guys will check it out.
    I did get the alternator workshop warning and my battery died on the way to work (after charging the battery all night - had the car booked in for a service the next day, so was trying to leave it till then to get it checked out as had had some false warnings flash up in the few weeks I have owned it and thought this might have been another one!)
    Had the new one fitted at a VW dealer.
  8. Re: Squealing noise from engine when idling
    I had a few alarms over a week then I had a noise from the front, the pulley had seized, I changed it and it has been fine for the last month, has the pulley got a black plastic cap? Have you checked the tension on the compressor belt?
  9. Re: Squealing noise from engine when idling
    Mar 2007
    Suffolk
    Dont underestimate the importance of getting this sorted asap.A seizing pulley could shear off the idle tensioner bolt which will then involve replacing cambelt/tensioners and getting sheared bolt out of the alternator ali casting!
  10. Re: Squealing noise from engine when idling
    As Mike posted if it is the alternator pulley sprag clutch seized, the belt can come off and go into the cam-belt pulley on the crank (I am sure I read of this happening) this could wreck the engine!
  1. Squealing/vibrating noise
    By ince03 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2011, 08:35 PM
  2. Engine noise and idling at startup
    By ricx2004 in forum Bora - 1998 - 2005
    Last Post: 09-10-2009, 09:00 AM
  3. Please Help squealing noise when cold
    By bodger5 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-06-2009, 01:57 PM
  4. ticking noise when engine idling
    By roguetone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2008, 10:47 AM
  5. Squealing noise under bonnet
    By animal in forum Polo - Derby - Lupo - Fox
    Last Post: 02-06-2008, 10:38 AM
