Thread: What auto gearbox type is it ????
Results 1 to 10 of 11
  1. Question What auto gearbox type is it ????
    Mar 2012
    Loughborough
    Its my first post , please be gentle
    As I'm off work with a painful kidney infection , so I've joined this group today
    I'm wanting to buy a A4 convertible but my wife will only drive an auto....Ive searched the posts for more than an hour but I'm still confused
    One thread had 15 replies and still I couldn't tell what is a multitronic or tiptronic ..
    Please help as the sun is out and I would like to get a car soonest
    many thanks in advance
  2. Re: What auto gearbox type is it ????
    Dec 2009
    southampton uk
    The quattros are tiptronic and its the best auto
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Multitronic is the continuously variable transmission (CVT) and is fitted to front wheel drive cars. There are numerous reports of issues with some of the earlier examples fitted in B6 models. Tiptronic is a traditional automatic gearbox and is fitted to quattro models. It seems to be far more robust and reliable from what I can gather.
    MF.
    Sent from my iPad using Tapatalk HD
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  4. Re: What auto gearbox type is it ????
    Mar 2012
    Loughborough
    I fully understand the concept of each gearbox function but from looking at the gear lever , which is which ?
  5. Re: What auto gearbox type is it ????
    Jan 2012
    Bristol
    Quote Originally Posted by psv6 View Post
    Think the gear lever's look the same. If you go for a Quattro, it will be the tiptronic box. If you go for the more comon 2WD it will be multitronic (cvt)
    I have a later multitronic (2004 onwards) with sports mode. It's simply the smoothest auto I have ever owned or driven. You can also select a six speed tiptronic mode if you like to select your gears manualy.
  6. Re: What auto gearbox type is it ????
    Mar 2012
    Loughborough
    With all this Audi knowledge , does nobody know how to tell them apart ?
  7. Re: What auto gearbox type is it ????
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Gear-lever is the same. 2wd = Multitronic, 4wd = Tiptronic. In operation they both do the same thing, just the Multitronic is better on the diesels than the tiptronic.
  8. Re: What auto gearbox type is it ????
    Sep 2011
    Shannon, Ireland
    Just a wild guess, as I've never driven an Audi with auto gearbox, but did some other ones with gears and variator auto gearboxes: take it for test drive and see, if it changes revs when changing gears, it's tiptronic, if revs are same and speed increases, it's multitronic which is a variator gearbox with virtually no gears. Although it has a mode in which it acts as normal auto gearbox. Just make sure you don't floor it all the time, just take it handy and watch rev counter. Apart from that I don't think there's way to tell diff between those.
    Hope it helps
    Regards
    Ruslan
    2001 Audi A4 2.0 20V
    1995 VW Polo 1.05-sold
    Mod's so far: cruise control and DIS retrofitted, two cup holders in dash
    Mod's to come: ESP switch and card holder relocation, color DIS, extra lighting
  9. Re: What auto gearbox type is it ????
    Jan 2012
    Bristol
    The two ways to tell the difference is. If there is a Quattro badge on the boot it will be conventional six speed auto. If you test drive in normal drive mode you will feel the gears changing.
    If it's a 2wd cvt there will be no gear changes. However both gearboxes have six speed tiptronic mode allowing you to sellect gears manualy by flipping the gear leaver or steering wheel controls if fitted. Both boxes have kickdown in drive or sports mode. My cvt 'multitronic' box has excellent three stage kick down.
    May 2009
    69 Post(s)
    Yes - we do, and we told you already. Front wheel drive cars have the Multitronic box and quattro cars have the Tiptronic box. Simples.
  1. Gearbox Code (Type) Help Needed
    By Paul Barls in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-12-2010, 09:24 PM
  2. Manual gearbox oil type
    By shabazmo in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2010, 08:39 PM
  3. Question easiest way to know your gearbox type
    By dansansome in forum Chat - Anything with wheels
    Last Post: 25-07-2008, 09:57 AM
  4. Gearbox & final drive type
    By nickynibbles in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-08-2007, 09:15 PM
  5. VW Auto Box Fluid Type?
    By Turkster in forum Passat - Archive Topics
    Last Post: 12-07-2007, 05:59 PM
