Thread: 3.0 Tdi Cam belt or cam chain
Results 1 to 8 of 8
  1. 3.0 Tdi Cam belt or cam chain
    Jan 2012
    Oxford
    Hi all can some one tell me wether I have a cam belt or cam chain. I have a 3.0 Tdi cab b7 on a 2006 plate. Also if it is a cam belt what's a good price to have it replaced, I'm sure I've read that it needs changing at 70,000 miles and I'm on 67,000 miles now.
    Regards Liam
  2. Re: 3.0 Tdi Cam belt or cam chain
    May 2010
    Devon England
    Just looked on autodata and it gives it as CHAIN, 3 chains are used by the looks of it
  3. Re: 3.0 Tdi Cam belt or cam chain
    Feb 2010
    Wirral
    yep, definately chains and recommended replacement seems to be around the 180k to 200k though some done more, however I'll be making sure I have part ex'd it by then as apparently it's an engine out job and £1000+ bill
    1986 Coupe quattro, (looks standard but hides 420bhp 20Vt).
    2004 A4 2.5TDi (163bhp) Sport cabriolet. Economy remap to 180bhp.
    2011 A5 Sportback 3.0TDi S-Line manual.
  4. Re: 3.0 Tdi Cam belt or cam chain
    Jan 2012
    Oxford
    Blimey now there's service for you , cheers guys.
    Regards Liam
    Leicester
    Have read that you should listen out for chain rattle on startup which can be an early sign of trouble. Apparently the chain tensioners have been known to go. If you search this I'm sure you'll find more info - I can't be sure I'm remembering exactly right.
  6. Re: 3.0 Tdi Cam belt or cam chain
    Feb 2010
    Wirral
    Quote Originally Posted by A4Ade View Post
    EArly cars suffer from this as the tensioners back off once the oil presure drops, but so long as the rattle goes within a second its OK. There is a fix (fitted to later cars) but at £1000 as its an engine out job I put up with it on mine...
  7. Re: 3.0 Tdi Cam belt or cam chain
    May 2012
    Lincolnshire
    Mine clatter loudly for a second or two at startup 50% of the time.... makes me cringe! I'm worried that one day something in there will fail and my engine will be scrap
  8. Re: 3.0 Tdi Cam belt or cam chain
    Feb 2010
    Wirral
    No need to Panic unless the noise doesn't go away at all, then its switch off the engine and quickly see your bank about a loan... Apparently they get to a point when they need changing from around 180K miles, depending on type of driving you have done. Will have sold mine before then hopefully
  1. cam belt or chain
    By cremator in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2010, 07:29 PM
  2. Chain or Belt cam
    By Anthony M in forum Golf MK6 - 2009 - 2013
    Last Post: 21-10-2009, 07:10 PM
  3. Cam belt or chain ?
    By noddy1875 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2008, 10:09 PM
  4. Audi 80. Cam belt or Cam chain?
    By Coastie in forum 80 - 90
    Last Post: 03-01-2008, 09:29 PM
  5. Cam belt or cam chain
    By GG_Audell in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2007, 06:15 PM
