Thread: Fault code 00739
Results 1 to 10 of 12
  1. Fault code 00739
    Nov 2011
    stoke on trent
    We have recently had our car scanned again by Mark, and we keep on getting a returning fault and wondering if anyone knows what it will take to fix this before taking the car to Audi and having to pay them nearly £100 just to check it out.
    This is the faullt reading from the VAGCOM
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 M
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000030162347
    Coding: 0001046
    Shop #: WSC 02325 785 00200
    VCID: DBBE1DA01A3E21B
    1 Fault Found:
    00739 - Coolant Circulation Pump (V50)
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 189530 km
    Time Indication: 0
    Date: 2012.03.04
    Time: 12:22:58
    Freeze Frame:
    Temperature: 80.0°C
  2. Re: Fault code 00739
    46 Post(s)
    Does the heat blow cold when the temp is set high?
    Have a look here - https://www.vwaudiforum.co.uk/forum/s...ating-problem&
    Replied to your PM too
    Oct 2010
    Here And There
    Is your MIL light coming on ?
  4. Re: Fault code 00739
    Nov 2011
    stoke on trent
    When I turn the heat up the car warms up nicely inside and also when on cool it seems to blow cold also, and there is no MIL light on. We are driving the car to Salou in the summer so hopefully will have aircon working ok lol
  5. Re: Fault code 00739
    Nov 2011
    stoke on trent
    Also wondering is this pump easy to reach if I get the parts and replace it myself as been trying to find the info on Elsawin 3.91 but cannot find any info relating to it
    Oct 2010
    Here And There
    With the upmost respect, if the car has no warnining lights on the dash and you cannot find ANY problems with the car, you deserve to pay Audi £100 to look at it. Matey honestly, why the hell are you chasing s fault code that is not causing any problems ? A glitch in the Matrix ?
  7. Re: Fault code 00739
    Nov 2011
    stoke on trent
    Thanks for the reply, and the reason I am chasing it is to try and get as much info as possible as not sure what the defect should be with this fault and I thought this forum was the place to ask questions, but obviously not lol.
    We are not getting really hot weather just now so unsure if the aircon is working to full capacity with this fault as the cold air might be coming in from outside and I grudge giving Audi £100 just to look at a car, sooner some of these dealers start having financial difficulties the better and perhaps costs may get back to sensible levels instead of thinking we are main dealers and like to rip people off.
    Oct 2010
    Here And There
    I dont mean to be unhelpfull but I do this for a living day in, day out. Watching people having to spend £100s or even £1000s of their hard earned cash that most people dont even have to spare to pay for expensive parts. To see someone chasing a fault code that has absolutly no meaning or will cause no trouble but simply because their wee buddy has a copy of VCDS and it says there is a fault there. Gets on my nerves just. Im a friendly, helpfull guy really but just not when it comes to ( in my eyes ) silly weekend mechanics trying to solve trouble codes. My humble appologies for being a ******* Rant over
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by A4 Lad View Post
    Spot on
    Sent from my iPhone using
    My fat fingers
  10. Re: Fault code 00739
    Ambler, PA, USA
    Quote Originally Posted by tonyandkaty View Post
    Coding: 0001046
    1 Fault Found:
    The fact that code is shown as being Intermittent means that at the time of the scan, the fault was no longer present - the fault happened at some point and was not present at the time of the scan... Clear the code and in a few weeks scan to see if it returns. If it does and you notice a problem with the car, take it to have it serviced... I do not believe you have a major worry here.
  1. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
