Thread: A4 B6 Right Dipped headlight fault(not the bulb)
  1. A4 B6 Right Dipped headlight fault(not the bulb)
    Hi, I recently has a dipped headlamp failure appear on the dash, i replaced the bulb but no joy. Got the multimeter and tested but wasnt getting any voltage to the dipped beam? I tested the rear of the light switch and i have 2 cores that get 12v when i switch on dipped beam, left and right i assume. still nothing at the head lamp. This has me puzzled,there are no fuses installed either in slots 21 & 22 for dipped beams. i assume there is a relay somewhere else that may be faulty.Has anyone come accross this before? Any help is greatly appreciated. Cheers.
  2. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    Apr 2009
    I thought the fuses were 20 and 21, there's no relay as such, it's switched through the
    steering column lever http://www.audiworld.com/tech/elec114.shtml
    Might be worth checking the headlight loom connections aswell.
    Regards
    Jim
    Still Crazy After All These Gears
  3. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Check that the spades in the connector haven't been pushed through. They tend to get a little easy to push out as I've noted on a couple of occasions - in fact one of my connectors has become somewhat brittle and they slip through easily.
    Cheers,
    Dan.
  4. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    Thanks for the replies lads,
    Jim: i looked at the step by step guide which is very good but doesnt seem to be the same setup as mine. It looks more like a B5 pre 2002 model??? Mine is a 2002 B6 with the headlight switch mounted on the dashboard below the air vent.
    Dan: I looked at the connections and they are fine, still getting no voltage at the spades.
    I looked at the wiring diagrams in the haynes manual and it seems everything is connected to a lighting control module behind the dash somewhere. Still no joy with this fault, any help greatly appreciated. Cheers.
  5. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    Apr 2009
    Quote Originally Posted by Strutt View Post
    It's your headlight dip switch I was on about
    Regards
    Jim
  6. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    Feb 2009
    I have exactly the same problem. Did you get it sorted?
  7. Re: A4 B6 Right Dipped headlight fault(not the bulb)
    And so do I! Mine's somewhat intermittent, so safely presume it's not the bulb itself.
  1. Dipped Bulb Recommendations
    By Brydo666 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-06-2011, 10:45 PM
  2. Headlight dipped beam - bulb replacement
    By JimC64 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-05-2011, 02:16 PM
  3. Dipped headlight bulb type
    By snewt in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2009, 10:12 PM
  4. Which Xenon HID bulb goes in Dipped headlight
    By Vwsteve76 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-11-2008, 09:05 AM
  5. A6 Saloon SE 2003 (03) Dipped bulb H1 or H7?
    By Naseem in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-10-2008, 05:27 PM
