Thread: droning noise
Results 1 to 8 of 8
  1. droning noise
    Feb 2011
    carnoustie uk
    hi there, hope someone can help me with an annoying droning sound coming from the front of the car(it's not the wife before anyone tells me). Thought it was wheel bearings but had both fronts replaced and it's still there. the noise is not engine speed or load related but vehicle speed. the noise seems to start around 30MPH and progressively gets louder as the car gets faster. it did get quieter when the wheel bearings were done but within a week it was back to being noisy. Starting to think it might be the bearings on the flange shafts that are bolted to the front drive shafts.The drive shafts will have been disturbed when the new wheel bearings were done and this might be why it got quieter for a while.
    anybody had anything similiar?
    the car's a 2006 2.0TFSI Quattro with high miles 116k.
    Paul
  2. Re: droning noise
    Mar 2008
    High Wycombe
    Have you tried swapping the tyres around? Sometimes, tyres wear teh tread blocks to a saw tooth pattern, which causes a droning noise on the road.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: droning noise
    Feb 2011
    carnoustie uk
    yeah that was the cheapest and first thing i tried, thanks though.
  4. Re: droning noise
    Aug 2009
    Near Lanark
    21 Post(s)
    Paul
    It could even be the brand or type of tyre you have.
    I found that my Kumho Ecstas were noticeably quieter than the Avons that I removed.
    Have you checked the undertray? Could it be catching the wind and either causing some sort of turbulence or even vibrating?
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  5. Re: droning noise
    Mar 2009
    You may have a mis shaped wheel (thanks pot holed britain), try swapping a wheel front to back. If the sound moves probably the wheel being slightly egg shaped and feeding a vibration back into the car. This has happened to me unfortunately
    Had huddersfield chip tune remap 50/50 power/economy - (july 11)
    Remap seems good, car smoother & more willing to hang onto higher gears, reeckon on 10% better mpg.
    A4 3.0 tdi semi automatic, sline quattro avant, leather through, bose stereo and 18" 9 spoke wheels
  6. Re: droning noise
    Dec 2011
    Newport UK
    Quote Originally Posted by paulperrie View Post
    Paul
    Funnily enough I've just posted a similar question on the Jetta section. I also was going to do a wheel-swap, but having read your posts I'm beginning to wonder if it's worth the bother.
  7. Re: droning noise
    Oct 2010
    Harrogate, n. yorks
    Betcha it's the tyres. Replaced three wheel bearings unnecessarily on mine because I couldn't believe that tyres alone could become so noisy. Changed to my winter wheels and the noise disappeared. Left with two scarcely worn tyres that are unuseable.
    Deaks.
  8. Re: droning noise
    Feb 2011
    carnoustie uk
    thanks for all the posts, will try and get a shot of wheels and tyres off my friends A4 and take it from there.
  1. strange droning noise
    By markgrff17 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2011, 10:48 PM
  2. Please Help Droning noise...
    By asterix in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-05-2010, 12:30 PM
  3. Droning Noise
    By Somerset v6 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-03-2010, 03:30 PM
  4. Please Help Droning noise from rear
    By LLucifer in forum The Commercial Range
    Last Post: 15-04-2009, 05:00 PM
  5. Humming/Droning Noise
    By GSD in forum Passat - Archive Topics
    Last Post: 13-02-2007, 08:17 AM
