Thread: Random Yellow Steering Wheel symbol
Results 1 to 10 of 16
  1. Random Yellow Steering Wheel symbol
    Mar 2009
    York
    I've done enough research on these forums to know that a possible fault on an ageing Passat B6 is the steering lock failing. This will mean the car doesn't start up, or shuts off immediately after starting.
    However over the past week I have had two or three random incidents of the yellow warning popping up, and 'steering lock fault see workshop!' fault displayed on the MFD.
    Both times the car has started and run for the journey. Both times the warning has gone after stopping, turning the car off and on again. There is still the audible lock/unlock sound of the steering lock mechanism.
    Is this just a matter of time before it gets worse. Last time it happened was about 3 days ago, and I'm certainly not going to do anything further until it gets noticeably worse.
    Other searches I've done only involve Passats which refuse to start up. Mine hasn't yet, and quite happily drives even with the warning on.
    Any advice gratefully received!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: Random Yellow Steering Wheel symbol
    Mar 2009
    Sleaford, Lincs, UK
    What year is your Passat??
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  3. Re: Random Yellow Steering Wheel symbol
    Mar 2009
    York
    2005, 55, so probably the earliest you could get!
  4. Re: Random Yellow Steering Wheel symbol
    Norfolk
    When the steering lock retractor and switches are a bit slow to respond, you can beat them by pushing the key to the start position too quick. That puts the yellow steering wheel light on. If yo go a bit slower from ign to start, you will probably be ok until the day when the micro switches don't react. Then it won't start.
    1 1 0
  5. #5
    Mar 2009
    York
    Thanks Martin, I'd guessed that maybe going too quickly wasn't helping. Past couple of days I have popped the key in, waited for the symbol to go out, then started the car... And no problems.
    I'll see how it goes. Yes there may be an inevitable ending , but then again may not be... Who can tell?!
  6. Re: Random Yellow Steering Wheel symbol
    Apr 2007
    France
    12 Post(s)
    I often started mine like that until I started reading about steering lock problems on here some years ago, since when I've made sure I always let the symbol go out.
    I haven't got a clue if it makes the slightest difference to the longevity of the switch though!
    1996 Laguna 2.2D
    1977 MGB roadster
  7. Re: Random Yellow Steering Wheel symbol
    Mar 2009
    York
    I suppose as Martin says if you beat the system by being too quick. Yes it does show that perhaps it is operating not as fast as when it was new, but to date no more errors, and since I'm keeping the car for another 18 months max, I'm prepared to do this each time rather than fork out money for the steering lock fix...
    Quatrelle, where your symptoms exactly the same as mine, as in the car was always driveable? If so, how long ago was that?
  8. Re: Random Yellow Steering Wheel symbol
    Jan 2009
    Leeming, Northallerton - North Yorks
    Has anyone tried removing the 'Locks/splines' or what ever they are. So the steering lock would still move to lock the wheel but it wouldn't actually lock. Could stop wear and tear on the lock. I know you would be left without a steering lock but they can be broken by the determined thief anyhow. Thoughts??
    Mar 2009
    York
    Though complete failure hasn't happened to me, I believe this fault should be treated just like the injectors by the dealers. Unacceptable that this fault should occur when it is integral to the operation of the car...
  10. Re: Random Yellow Steering Wheel symbol
    Dec 2009
    14 Post(s)
    Quote Originally Posted by Quatrelle View Post
    Same here.
  1. Question Yellow Steering Warning Light on Dash with no Symptoms.
    By ric4676 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-03-2012, 10:03 AM
  2. yellow steering symbol diagnosis
    By pemac in forum VCDS - Help Requests
    Last Post: 27-04-2011, 10:22 AM
  3. Yellow steering light
    By slimgeo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-09-2010, 08:50 AM
  4. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
  5. Yellow car symbol under rev counter flashes on 1998 A3
    By kklown in forum Audi A3 - Archive Topics
    Last Post: 13-02-2008, 09:37 PM
