Thread: How to bleed out air from the cooling system on a 1.9TDI?
  1. How to bleed out air from the cooling system on a 1.9TDI?
    VAGMAN2 Guest
    When I open the expansion tank cap on my Mk5 1.9TDI, there's a whoosh of air and the coolant level rises by about 2cm. This coupled with the fact that the heating is only blowing lukewarm makes me think there is air in the system.
    What's the correct way to bleed out air from the coolant system?
    Thanks in advance.
  2. Re: How to bleed out air from the cooling system on a 1.9TDI?
    May 2007
    knee deep in clunge
    14 Post(s)
    pressure/vacuum bleeder spot on no problems
  3. Re: How to bleed out air from the cooling system on a 1.9TDI?
    VAGMAN2 Guest
    What's one of these and how does this work, then?!
    Are there no bleed points for air around the coolant system, on the Mk5?
  4. Re: How to bleed out air from the cooling system on a 1.9TDI?
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by VAGMAN2 View Post
    tool http://www.ntxtools.com/network-tool...ROB-75260.html
    no bleed points
    Feb 2010
    basingstoke
    You may want to check your getting flow into the expansion tank from the small pipe ie the return if it is not flowing steadily back then I would suspect water pump impeller may have fallen off this causes improper circulation of coolant around the system higher pressure and poor if any heat within the car. It's also worth knowing that vw are very easy bled ie run it without the cap onfrom cold topping it up untill it has the correct level road test it at least five miles let it cool down and recheck if level is good that's it if not top up and done!!!
  6. Re: How to bleed out air from the cooling system on a 1.9TDI?
    Jan 2019
    Dagenham
    Did you fix this at all mate?
  1. Please Help 98 Audi a4 1.9tdi Engine code = AHU Air Flow System Help
    By DaveDeMan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-10-2010, 10:54 PM
  2. bleed screws in cooling system
    By chimo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2010, 09:28 PM
  3. air bleed screws in cooling system
    By chimo in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2010, 12:09 PM
  4. air in the cooling system
    By lliikk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-01-2010, 02:31 PM
  5. Mk3 golf 2.0 gti / air in cooling system
    By Happy_Trucker in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2006, 01:26 AM
