Thread: Vinyl wrapping to dechrome
Results 1 to 10 of 17
  1. Vinyl wrapping to dechrome
    Aug 2009
    Near Lanark
    21 Post(s)
    Hey.........
    I bought some vinyl wrap from ebay and today tried to wrap my grille chrome edging.
    My first thought was to try and cut a piece large enough to allow me to do the whole thing without a joint....but when I sat down to try that, it appeared nigh on impossible (for a novice like me anyway).
    So I resigned myself to have a joint or two. I figured I could get a clean cut and make the joint almost invisible.
    What a nightmare it was to try and wrap even just the top part of the grille. First time I got a load of wrinkles at the ends where the chrome turns down the way. So I thought I'd dodge that problem by having a couple of joints....but again....a nightmare to get the stuff to sit properly, and stick without wrinkling and bubbling.
    I admit I'm making it slightly harder by trying to do it with the grille fitted to the car but I really don't have the facilities or knowledge to remove the bumper and grille.
    I even tried to cover the chrome trim on my rear bumper and it was tricky too - trying to get it under the protruding bodywork and not stick to the chrome until it's in position is difficult.
    Is the problem that it's too cold? and making the wrap less pliable and elastic?
    Or is it just me being hamfisted and inexperienced?
    Any tips?..apart from the obvious of remove the grille which is not really something I want to tackle.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  2. Re: Vinyl wrapping to dechrome
    Feb 2009
    Essex
    Quote Originally Posted by darich View Post
    Hey.........
    The No1 tip......Use a hairdryer...it's a must, makes it really pliable, much easier to use. I removed the grille to do mine, but using the hairdryer allowed the flexibility to only have one join at the bottom....hope this helps fella.
    Mac
  3. Re: Vinyl wrapping to dechrome
    Aug 2009
    Near Lanark
    21 Post(s)
    Thanks Mac
    Couple of questions then.......
    1 - I've got a roll approx 600-700mm wide but something like 10m long. Would the hairdryer allow me to cut a long strip and bend it around the corners without wrinkles?
    2 - Is it easy to remove the bumper? It would be easier to do the work in the warmth of the house rather than the cold of the driveway....unless I wait till spring/summer!!
    3 - how did you tuck the vinyl under the top edge of the chrome? I cut a vertical slit and managed to get it inside the grille but I wondered if there was a better way?
    4 - do you have any photos of your car after you did it?
    Thanks!!!
  4. Re: Vinyl wrapping to dechrome
    Feb 2009
    Essex
    1.I basically cut a piece large enough to lay over grille then cut the inner out, used the hairdryer to warm the vinyl making it easy to mould to the contours of the grille, took awhile as I went slow to make it right, although i did peel back a bit then redo.
    2. http://www.audizine.com/forum/showth...Bumper-Removal I used this & had a mate help, took about 20mins to remove.
    3. I didn't tuck it under the grille at the top, I overlapped the chrome the carefully used a scalpel antrimmed the excess.
    4. pics >>
    After doing the grille I did the interior the same colour...looks great all round.
    Hope this helps mate.
    Mac
  5. Re: Vinyl wrapping to dechrome
    Aug 2009
    Near Lanark
    21 Post(s)
    Mac
    yours looks brill....and defintely makes want to persevere with it.
    My car is black and I originally was going to use matt black wrap, but then I saw a black car with gloss black and thought it looked great so I've got some of that wrap too.
    My idea was also like you started - a large sheet and cut out the inner.
    I expect it would be a ton easier if I can get into different angles and positions with the grille off. Also with the warmth of the house it must surely be easier.
    I also found that link and just spent the last half hour copying the text and all the pics into a word document for ease of reference.
    Is removal of the bumper feasible for one man?
    I expect removing would be easier than refitting....yes?
    many thanks for the replies and pics!!
    I've taken a "before shot" so when I get it done I have a comparison
  6. Re: Vinyl wrapping to dechrome
    Feb 2009
    Essex
    lots of peeps have done it on their own, I just had a mate help as it was gonna be easier.
    Good luck, looking forward to the pics.
  7. Re: Vinyl wrapping to dechrome
    Aug 2009
    Near Lanark
    21 Post(s)
    Cheers Mac
    Will maybe have a look at trying again next weekend.
    If I manage it I'll post a few photos.
  8. Re: Vinyl wrapping to dechrome
    Jun 2010
    Kings Lynn, Norfolk
    Just had a thought all you guys with the milky window trims, easy fix chrome vinyl wrap.
    170 bhp s line bose, cruise control, pdc, mfsw, flawless glossy black, Now hopefully reliable with it's new injectors
  9. Re: Vinyl wrapping to dechrome
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by gaz1965 View Post
    erm...and the point of this thread is.....??
    :-p
  10. Re: Vinyl wrapping to dechrome
    Jun 2010
    Kings Lynn, Norfolk
    :-p
    I know you are looking to dechrome. I can read.
    But there is a problem discussed on this forum with guys who want to bring the chrome window trims back to a new look. just pointing out a possible solution
  1. S5 Chrome Wrapping
    By tisheto in forum Body Work, Body Styling and Body Kits
    Last Post: 07-06-2012, 09:58 PM
  2. Vinyl wrapping
    By reddunk in forum Body Work, Body Styling and Body Kits
    Last Post: 20-01-2012, 11:47 AM
  3. Question Carbon Wrapping
    By Macdoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-12-2010, 06:51 PM
  4. Attention want to know how vehicle wrapping is done? - open day tomorrow 14th May
    By Totally-Dynamic in forum Shows & Events
    Last Post: 13-05-2010, 10:05 AM
  5. 90 dechrome
    By snigweed in forum 80 - 90
    Last Post: 03-02-2008, 09:11 PM
