Thread: Importing music into jukebox on AMI
  1. Importing music into jukebox on AMI
    Jul 2010
    Launceston, UK
    I have been trying to Import tracks from either home made CDs, bought CDs or from my Ipod into the Jukebox on my 2009 AudiA4.
    I click on "Import" and it says "select source" with the only option being from Audio CD, which is already selected. I can't work out what to do next, as it doesn't import the tracks.
    The Jukebox has music in it from the first owner, would quite like to delete it tbh. I wondered if it had anything to do with copyright, but my bought cds and self made ones the same.
    Any help much appreciated
  2. Re: Importing music into jukebox on AMI
    May 2007
    knee deep in clunge
    14 Post(s)
    Do you have vcds if so you can enable 5f to import for original discs and copy discs as you change the region coding which protects the copyright and thus stops you importing the music
    I will post it tomorrow as my notes are on my other laptop
  3. Re: Importing music into jukebox on AMI
    Jul 2010
    Launceston, UK
    Thanks. I don't have the vehicle cds unfortunately. It puzzles me that there is already music on the jukebox from the prior owner, so presumably there must have been some way of getting it on there.
  4. Re: Importing music into jukebox on AMI
    May 2007
    knee deep in clunge
    14 Post(s)
    How to enable music copying for genuine dvd music
    connect vcds
    Go to address 5f go to adaptation channel 6 set to 1 and save
    this how I enabled the hidden menu
    Reset mmi
    now enter the hidden menu
    Press and hold car and menu till green screen comes up for A7
    A8, Tone and Car for D4
    A5,A6 & A4 Q5 Q7 PRESS CAR & SET UP
    when the green menu comes on
    scroll down find
    diagnosis, settings, multimedia import of copy / no ripping to copy / ripping set.
    Set to 4/4
    Reset mmi and now you can rip the music to juke box
    mmi reset buttons see here https://www.vwaudiforum.co.uk/forum/s...873#post695873
    Jan 2011
    Bucks
    Not sure if your model has the sd card slot, if it does just copy your music onto the card then, when you pop it into the car you'll get an additional option to import from the sd card. No vcds needed, easy!
    Sent from my LT15i using Tapatalk
    MY2011 (Apr), A4 B8 Avant, 2.0 TDI 170 quattro technik in Brilliant Red. Full leather, DAB, Lighting pack, 3g MMI HDD Sat Nav, Parking Plus, AMI, Boot liner.
  6. Re: Importing music into jukebox on AMI
    May 2007
    knee deep in clunge
    14 Post(s)
    Jukebox
    The Jukebox is available for the storage of music
    files. Up to 3000 tracks can be stored in the Jukebox.
    The actual number of tracks is dependent on the
    compression of the audio files.
    Import function
    Music files in MP3, WMA and AAC formats can
    be read in from the following interfaces and
    imported into the Jukebox:
    – DVD drive in J794
    – Memory card reader in J794
    – Medium at USB port of Audi music interface
    (USB stick, hard drive, etc.)
    Music files on audio CDs cannot be imported. O yes they can by setting the value to 4/4
    Playlists (files with endings M3U and PLS) and DRM
    protected files are non-readable.
    Information electronics control unit -1- J794
    435_026
    Import Media Source
    Import new track
    Please select a source:
    SD card
    SD card
    DVD
    Control
    Display of imported tracks in the operating menu
    of the MMI
    Only files can be imported, not folders. Music files
    are organised by artist, album, track and genre for
    easy selectability.
    The artist, album, track and genre are read out
    of the meta information*, included with the track
    (e.g. ID3 tag*).
    If the source file does not contain any meta
    information, then the files are stored under
    Unknown artist, Unknown album, etc.
    Exporting and deleting music files
    Files cannot be exported from the Jukebox.
    Files can be deleted individually, by folder
    or entirely.
    If the Jukebox is reset to the factory default
    configuration, all tracks will be deleted from the Jukebox
    So setting the region to 4/4 allows direct ripping from original cd
  7. Re: Importing music into jukebox on AMI
    Jul 2010
    Launceston, UK
    Hi, thanks for that.
    The first bit totally lost me I'm afraid:
    connect vcds
    Reset mmi
    I tried when "media" selected clicking CAR and SETUP as suggested (for and A4 Audi)
    It comes up with something like "No further settings available for the car menu"
  1. Question MMI Jukebox Hard Drive question
    By Gardj in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-11-2011, 02:33 PM
  2. Importing from UK
    By Lion16 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-11-2009, 02:18 PM
  3. Importing files to MMI jukebox?
    By first_timer in forum In Car Entertainment
    Last Post: 31-01-2009, 10:19 PM
  4. Replies: 1
    Last Post: 07-12-2008, 03:27 PM
  5. Importing a used Audi from Germany
    By scootermap in forum Chat - Anything with wheels
    Last Post: 01-11-2007, 10:53 AM
