Thread: Finding the engine number
Results 1 to 10 of 10
  1. Finding the engine number
    Jan 2012
    Sandhurst
    I don't have any history with my car and I want to find the codes for the engine and gearbox. I looked in the spare wheel well and there is a sticky mark where I assume a label was with the engine number. Where else is the number on the car?
    Adam
  2. Re: Finding the engine number
    Mar 2008
    Just Cumbria now.
    Yes, you're correct that the label shows you the engine and gearbox codes, engine will be 3 letters, e.g. ATJ, and gearbox similar.
    Post up the list for the label (also should be replicated in service/handbook) here, and then someone will decypher it for you.
    Nothing to see here, move along..
  3. Re: Finding the engine number
    Jan 2012
    Sandhurst
    I don't have the label or the service book
  4. Re: Finding the engine number
    Mar 2008
    Just Cumbria now.
    Ah, then they are both stamped on the engine.gearbox, but don't ask me where!!
    Try asking your local Audi dealer, they should be able to give you the history.
    46 Post(s)
    Engine code should be on your v5 under engine number. Iirc the first 3 letters will be the engine code.
    If the car was serviced with Audi, then ring a dealer and they will be able to tell you as Hex says.
  6. Re: Finding the engine number
    Jan 2012
    Sandhurst
    I haven't got the V5 yet just the little green slip. I'll try Audi
    Adam
  7. Re: Finding the engine number
    Regards Peter
  8. Re: Finding the engine number
    Jan 2012
    Sandhurst
    Just rang Audi, apparently my car has never been serviced by Audi. They did have the engine code - AWX. They didn't have the gearbox code, does anyone know what its likely to be? 2002 5 speed manual.
    @Peter D, I looked in the spare wheel well and the label appears to have been rubbed off by the spare wheel
  9. Re: Finding the engine number
    So you have a 1.9 TDI PD engine. Either FNN or GGB. The blocks are marked but not in a common place.
    http://www.blauparts.com/audi/audi_e...ine_code.shtml
    Regards Peter
  10. Re: Finding the engine number
    Jan 2012
    Sandhurst
    Thanks folks
  1. help finding vin,chassis or frame number
    By aaudi4 in forum Golf MK3 - 1993 - 1999
    Last Post: 18-07-2011, 10:27 AM
  2. Help : Finding part number
    By jagr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2011, 06:45 PM
  3. Replies: 2
    Last Post: 10-09-2009, 01:27 PM
  4. Help Finding Engine Code.....
    By x51m017x in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2008, 10:20 PM
  5. Finding out engine output
    By thefreak in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2008, 10:28 AM
