Thread: Fault code 18043/P1635-008
  1. Fault code 18043/P1635-008
    Jan 2012
    Charlwood
    Please help.
    Just had problem with my audi a4 2.0 SE 2001. The A/C controller seems to be dead. Vag-Com scanning gives :
    Address 01: Engine
    Part No: 8E0 909 557
    Component: 2.0L R4/5VS 0001
    Coding: 0011501
    Shop #: WSC 63351 000 00000
    VCID: F0E4529EDCF9859C
    1 Fault Found
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 008 - Implausible Signal
    I tried my A/C controller unit fit into my friends audi a4 and it works. So my A/C unit itself works.
    Does anybody can help what to do?
  2. Re: Fault code 18043/P1635-008
    check the fuses
  3. Re: Fault code 18043/P1635-008
    Jan 2012
    Charlwood
    sorry, any idea witch fuse i should check?I checked all the fuses on right side where is all the fuses in car and they all look all right. I bought car with the problem like i mention above maybe my fuse i missing from the fuse box. Could you say witch exactly fuse i should check?
  4. Re: Fault code 18043/P1635-008
    if you have an 8E model check fuses 1 and 26 and 44 in the fuse box
  1. 02000 - Switch Position, 008 - Implausible Signal
    By netmonky in forum VCDS - General Questions
    Last Post: 27-08-2018, 02:34 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2009, 06:05 PM
  4. anyone know what to do with this error code.... 18043
    By boidy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-01-2009, 12:16 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
