Thread: A4 B6 2000 intermittent fault
  1. Question A4 B6 2000 intermittent fault
    Jul 2007
    Hi could anyone advise regarding a fault with my A4.
    The alarm has been going off, the rear doors remain shut (despite trying to open them from the inside and out), Interior lights are on and off and central locking has a mind of its own. These are just some of the faults which are all intermittent.
    I have done some reading up and it seems that the blame points to Central Convenience Unit. So I stripped the interior passenger area to expose the module and to my shock it seems to be dry as the Sahara. The surround wires are also dry, I also inspected the module for dry-joints and found it to be spot-on.
    Can anyone one advise where the fault may lie?
    Any help on the matter is greatly apprecited.
    Grover
  2. Re: A4 B6 2000 intermittent fault
    Jul 2007
    Hi guys been advised to scan with VCDS, results are as follows: (Please could a VCDS guru help me to decypher this lot?)
    VCDS-Lite Version: Release 1.0
    Sunday, 15 January 2012, 22:58:00:0
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: Redir Fail!
    Controller: 8E0 909 557
    Component: 2.0L R4/5VS 0003
    Coding: 0011501
    Shop #: WSC 63351
    1 Fault Found:
    17701 - Map Controlled Engine Cooling Thermostat (F265): Short to Plus
    P1293 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0010 0001
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    49-10 - No Communications - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Controller: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    Shop #: WSC 63351
    No fault code found.
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 D
    Component: KOMBI+WEGFAHRS. RB4 D14
    Coding: 00400
    Shop #: WSC 00001
    WAUZZZ8E82A014675 AUZ6Z0A0145618
    3 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01337 - Interior Door Handle Illumination
    49-00 - No Communications
    01339 - Door Warning Light
    Address 56: Radio Labels: 8E0-035-1xx-56.LBL
    Controller: 8E0 035 186
    Component: concert II GRO 0008
    Coding: 00201
    Shop #: WSC 00000
    1 Fault Found:
    01042 - Control Module; Not Coded
    35-00 - -
    End --------------------------------------------------------------------------------------------------
    Individual module scanned
    Sunday, 15 January 2012, 23:01:23:0
    Control Module Part Number: 8E0 959 433 AL
    Component and/or Version: Komfortgerát T9F 0514
    Software Coding: 07883
    Work Shop Code: WSC 63351
    Additional Info: 8E2959802B Tőrsteuer.FS BRM 4.11
    Additional Info: 8E2959801B Tőrsteuer.BF BRM 4.11
    14 Faults Found:
    53-00 - Supply Voltage Too Low
    01334 - Door Control Module; Rear Right (J398)
    01338 - Signal; Doors Not Closed
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    01332 - Door Control Module; Passenger Side (J387)
    01351 - Communication Wire at/to Ground (GND)
    37-10 - Faulty - Intermittent
    01590 - Igniter for Battery Disconnect (N253)
    35-00 - -
    01595 - Tire Pressure Control Switch (E226)
    35-00 - -
    01597 - Drive Battery Pre-Charge Circuit
    35-00 - -
    01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
    08-10 - Control Limit Surpassed - Intermittent
    00496 - Sensor for Vehicle Leveling; Front
    00490 - Right Rear Vent Temperature Sensor (G406)
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    Maybe someone knows of a work around for the time being as the alarm is driving the whole neighbourhood crazy.
    Any help on the matter is greatly appreciated.
    Grover
  1. 2000 1.6 SE - Intermittent EPC Light
    By love_my_golf in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2009, 04:44 PM
  2. Intermittent fault with ABS
    By davedru in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2009, 11:48 AM
  3. Intermittent lighting fault
    By jetdave in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2009, 06:23 PM
  4. 2000 Polo intermittent fuel gauge
    By richiej in forum Polo - Derby - Lupo - Fox
    Last Post: 31-07-2008, 10:34 AM
  5. 2000 TDi SE Tiptronic intermittent hunting
    By Audidothat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-03-2008, 02:43 PM
