Thread: Audi A2 Tdi 54 plate engine problems
  1. Exclamation Audi A2 Tdi 54 plate engine problems
    Aug 2006
    I have some serious problems with my Audi A2 1.4 Tdi 2004/54 plate.
    Basically the engine light is on and the code is V157 - Throttle Housing which needs replacing - where can i get this part cheap - shall i try a breakers?
    Also i have had the cambelt and water pump changed and the mechnaic told me that the tooth belt was previously out of line - which he has done a pucker job on.
    The car seems very sluggish to drive as if their is no turbo - it barely makes it up a hill in 2nd gear!! Why is this?
    Finally the sunroof rail guides and cables need replacing my mechanic friend says it has to be done by Audi as they have the tools
    I would appreciate your advice and help
  2. Re: Audi A2 Tdi 54 plate engine problems
    Jan 2009
    towcester northants
    gsf should do throttle valve
    you will need a diag test done to see if any faults on engine for turbo but it may be throttle valve
    why do the sunroof guides etc need replacing? not a common problem
  3. Re: Audi A2 Tdi 54 plate engine problems
    Sep 2008
    6 Post(s)
    There's a throttle control body (including EGR) on Ebay just now here: http://www.ebay.co.uk/itm/AUDI-A2-1-...#ht_500wt_1091
    More details here about cleaning throttle body here: http://www.a2oc.net/forum/showthread...-throttle-body
    When you say your mechanic changed the timing belt and waterpump - had the toothed belt jumped? Regards poor performance, if changing or cleaning the throttle body clears error but doesn't improve performance - then the MAF would be the next thing to look at.
    Regards opensky sunroof problems. As long as your A2 is less than 10 years old, has audi service history, take it to either Worthing Audi or Rinner in Germany. It's a big job from what I've read. Most Audi centres wouldn't know where to start. More details here: (including PDF repair guide) in German! http://www.a2oc.net/forum/showthread...nSky-is-reborn!
    2016 BMW i3 REx (80k)
  1. Please Help A3 3.2 (54 plate) Engine problems
    By KQuattro in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-03-2010, 08:20 PM
  2. Audi A3 1.9 tdi Quattro Sport Engine problems
    By theshowboat in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 28-04-2009, 10:24 AM
  3. Please Help 05 plate 2.0 TDi gear problems??
    By orbals in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-04-2009, 11:18 PM
  4. Please Help MK4 Golf PD TDI 150 02 Plate engine problems!!
    By C_jam01 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2008, 10:59 AM
  5. 55 plate A4 cab 2.5 tdi - is it a pd engine
    By nickbelluk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2008, 02:32 PM
