Thread: Whats an aux heater and what does it do?
Results 1 to 10 of 10
  1. Whats an aux heater and what does it do?
    Aug 2008
    Flitwick, Beds
    Hi Guys
    I've read through quite a few threads discussing faults relating to these heaters, but I think I'm a little confused as to what they're for.
    Not had any smoke from my 02 tdi, but I hear it clicking from time to time, and whiring after runs.
    Is it connected to the cabin heater system, as ours take forever to warm up in the winter. In fact this is the worst vehicle I've ever owned for winter demisting, and I've had some shockers over the years (HA Viva vans!!)
    Or does my air con need refilling? Ive had the car four years, it was recharged a while before we bought it when it had a hose replaced. Should it need doing again?
    Sep 2009
    ramsgate
    Aircon refill is for cooling not heat
  3. Re: Whats an aux heater and what does it do?
    Aug 2008
    Flitwick, Beds
    Quote Originally Posted by portovechios View Post
    But I thought the AC helped remove the moisture, therefore if it's not fully charged it won't help demist !
    Sep 2009
    ramsgate
    AC provides cooling when the temp you punch is lower than the ambient temp. So if its 25 outside and you punch in 20 the ac will come in and reduce the outside air coming in to help bring inside temp down.
    The time of the year the AC will not cut in because the ambient temp outside is lower than you require
    Climatronic is the whole system that controls this.
    If you're not getting heat it is nothing to do with the AC unless of course its stuck on.
    Climatronic is a wonderful thing but your problem could be one of many things.when you adjust the temp from say 20 to 16 you should hear flaps and motors in the centre console moving and ticking etc
    Does the engine temp get upto around 90 after 2/3 miles?
    Sep 2009
    ramsgate
    AC does not demist, heat demists
  6. Re: Whats an aux heater and what does it do?
    Aug 2008
    Flitwick, Beds
    Well I hate to disagree with you, maybe you justnever tried it. But if we leave ours in ECON with 3 or 4 body's in the car the side windows mist up quite quickly. Stick it back on AUTO and the air con kicks in, the mpg drops by a couple of digits and the windows tend to clear again.
    We also found it did it in our Avensis that we had before.
    Sep 2009
    ramsgate
    Climate control in auto will boost heat and exchange air as it sees fit.All i'm saying is that AC is just the action of cooling and is a part of climatronic.
    Regassing will not improve demisting but it will allow the climatronic to acheive lower than ambient temps
    It might be that in newer cars they have demisters, i don't know!?
    Hey..i'm no expert though
    That is my understanding anyway
  8. Re: Whats an aux heater and what does it do?
    Jul 2008
    Misting is the action of moisture or humidity in the air condensing on cold surfaces, in this case glass. Air conditioning acts as a de-humidifier.
    Climatronic set to auto has the air conditioning on all the time. The air is cooled by the evaporator, and is then heated to the required temperature in the heater matrix using the engine's cooling water. if the ambient temperature is below about 4.5C, the air conditioning is locked out by the car's system.
    With the OP's symptoms, I'd want to check whether the auxiliary heater is actually getting hot and whether the engine thermostat is working
    My auxiliary heater was very unreliable and I didn't want to spend approx £500 on a replacement. I too, therefore, suffer from slow warm up. What I do in cold weather is to turn off the heating altogether until the engine has got to temperature. If I do this, the engine warms up more quickly, and heating is more effective as a result. In the meantime I rely on the heated seats. I don't find it worth bothering to do this unless the temperature is below about 5C
  9. Re: Whats an aux heater and what does it do?
    Mar 2009
    I have the same issues with the Aux heater and I recently turned the on board controls to ECON and fingers crossed no more smoke in the cabin as long as I keep the heater on full blast!!!!
    It takes a long time for my Sharan to heat up is there anything I can do to sort this issue out?
  10. Re: Whats an aux heater and what does it do?
    Jan 2013
    Stord
    Might be a little late, but i have heard of a guy that had this problem with sharan taking loads of time warming up(this was even with the auxiliary(booster) heater working). He problem solved this and changed the electric water pump(though he had installed a parking warmer) and it still would take alot of time to warm up the car.
    He however got a tips and solved the problem.
    The tip was to putting the car in a very steep slope with the front upward. Then race the engine at high speed for 5 minutes. (3500 rpm) This with the lid of the expansion tank off.Then the water pump circulating the water is in a suitably high speed and squeezes out air that may be in the system. This should be a self ventilating system on the car.
    After a couple of minutes the heat came. He said he have never had it so hot in the heating system earlier. The next morning he tested the system and after 20 minutes it was tremendously hot in the car.
    Worth a try if you have fixed the aux heater and it doesnt get warm enough.
  1. Great heater performance, does my B6 have an aux heater fitted?
    By andrewturner in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-11-2011, 12:38 AM
  2. Sharan Aux heater
    By tona955 in forum Touran - Sharan - Caravelle
    Last Post: 06-12-2010, 06:43 PM
  3. aux heater help
    By kirkyboy in forum Touran - Sharan - Caravelle
    Last Post: 25-03-2010, 08:57 AM
  4. tdi aux heater
    By bhprs in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-01-2009, 07:27 AM
  5. Question Aux Heater
    By Kj5cott in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-01-2009, 04:10 PM
