Thread: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
  1. Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    Oct 2010
    United Kingdom
    I had a problem with a Golf 1.9 TDI 2002 - the battery, ABS and EPS lights kept coming on and the interior lights went off a few times and it said "Workshop Alternator" on the dashboard.
    A VAG speciliast (not main dealer) has had a look and unfortunately it has been diagnosed as needing a new alternator - was hoping just a wiring issue :-(
    I have had widely varying quotes and information - some people quote for Bosch/Lucas only as original VAG. However, I have been quoted for a Hella alternator with the garage saying it is top class - exactly the same as Bosch etc...and that VAG can change suppliers even part way through a production run (i.e. first 100 cars = Bosch, 2nd 100 cars = Hella).
    Quotes varied from £170 to £260 ex. VAT but inc. fitting.
    Not sure of the above and looking for a 2nd opinion....its done 150k miles and has had the cambelt done recently...I am hoping to get another 100k miles out of it without more major expense other than services.
    tomhass
  2. Re: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    Oct 2010
    United Kingdom
    Hi All
    Anyone got any opinion on the Alternator ? - I sure could do with some advice and need to fix it soon :-)
    tomhass
  3. Re: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Bosch & Valeo were original equipment manufacturers / suppliers (OE.M.) to VW so their quality is 1st rate.
    It might be prudent to have the voltage regulator ( part of Alternator) checked out, before replacing the complete alternator, as it may be a simple case of brush wear or the actual voltage chip that needs replacing.
    Skoda Octavia II SE 1.9PD TDI
  4. Re: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    130 Post(s)
    1972 Post(s)
    If you want the best, get a VW exchange unit from the dealer, it has a 2 year parts and labour warranty.
  5. Re: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    Aug 2023
    Canada
    Good day,
    I was wondering how Hella alternators hold up. Did you end up buying it? Is it still going strong? Do you have a very rough guess on how many kms you put on the alternator?
    Thanks for your time
    cheers
    Lex
    BTW. There still doesn't seem to be much talk of Hella Alternators on the internet if they're good or bad. It doesn't help that the name is not the greatest. People like to use the word "Hella", for things like "it was a hella of a good night" and such. Also Hella lights seem to be pretty popular conversation on the web. This leads to a lot of bad search results.
  6. Re: Golf 1.9 TDI 2002 - Alternator - Bosch vs Lucas vs Valeo vs Hella
    130 Post(s)
    1972 Post(s)
    In the UK Hella remanufactured alternators are not readily available and I don’t know if they make them new. The only two common brands of rotating electrics we see are Bosch and Valeo.
  1. Question bearings for Bosch alternator
    By Docho in forum 80 - 90
    Last Post: 13-06-2010, 12:00 PM
  2. Removing alternator 2.5 TDI 2002
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2010, 09:38 PM
  3. Please Help Did the Golf 3 have Valeo alternators?
    By funky_monkey74 in forum Golf MK3 - 1993 - 1999
    Last Post: 11-11-2008, 09:25 AM
  4. 2002 Polo TDI Airbag Light stays on after fixing alternator wiring fault.
    By Veedubmad in forum Polo - Derby - Lupo - Fox
    Last Post: 27-01-2008, 06:07 PM
