Thread: Q5 MMI Bluetooth Connection
  1. Q5 MMI Bluetooth Connection
    Dec 2011
    Worcester
    Hi I have a Q5 with MMI 3G Navigation.
    I have read elsewhere that the Bluetooth and phone system is installed in all of these but not turned on or activated unless that option was paid for.
    Can anyone tell me if this is true?
    If it is correct, how do I go about activating it without paying lots of money to the main dealer?
    Grateful in advance for any help.
    Dave.
  2. Re: Q5 MMI Bluetooth Connection
    May 2007
    knee deep in clunge
    14 Post(s)
    you need to retro fit the mic and then enable the 5f control unit then adapt the bt
    or pay some one to do it for you
    the dealer will not touch this at all and unlikely they even no it can be done but depending on the mmi 3g version use the kufatec kit for laymen and this will work for you but you still need vcds to enable 5f http://www.kufatec.co.uk/shop/produc...oth-Only-.html
    if none of this makes sense pay some one who knows as messing around with 5f control units is not for forum fiddlers and vcds tweekers
  3. Re: Q5 MMI Bluetooth Connection
    May 2007
    knee deep in clunge
    14 Post(s)
    Bluetooth activated when MMI 3g installed
    In the Audi MMI Navigation System and built-3g you activate the Bluetooth option.
    Here are two activities are necessary:
    • Unlock the hidden menu of the MMI 3G and activation of Bluetooth
    • Coding / adaptation of the infotainment control unit with respect to Bluetooth Module
    The following coding is used:
    • Unlock the hidden menu of the MMI 3G and activate the Bluetooth
    1. STG 5F (infotainment) select
    2. STG adjustment -> Function 10
    3. Channel number 06
    4. New to this set: 1
    5. The menu can be hidden with the shortcut setup + Car (both keys together) open, where you must first press the Setup button.
    6. Now, in the Hidden menu under Diagnostics -> settings point to the 'Phone settings misc' adjust accordingly:
    7. From: no BT -> BT
    1. MMI reset
      (Press and hold down the button -1 - (setup), the confirmation button -2 - and the navigation key -3 -. The same MMI then shuts down and restarts lasts about 60 seconds.)
    3. Channel 17 - Bluetooth module (internal)
    4. Default: 0
    5. New to this set: 1
    To turn on Bluetooth (only 3G MMI)
    Enabling hidden menu (Hidden Menu)
    - Connect the cable to run the software and VCDs
    - Enter the form 5F
    - Click on Adaptation - 10
    - Select Channel 6 and then "Read"
    - Set the New value to 1
    - Click on "Test"
    - Click on "Save"
    - Click on "Done, go back"
    - Exit VCDs
    - Enter the hidden menu by pressing SETUP CAR + for 6 seconds
    - Select Diagnose> settings> Phone settings misc
    - Change to [no WLAN / no NAD / BT / HFP] 4 / 16 and confirm
    - Exit the menu by pressing CAR
    - Restart the MMI pressing SETUP + + WHEEL SELECTION MENU BUTTON IN TOP RIGHT for a few seconds and release
    - Enter the form 5F
    - Select Channel 17 and then "Read"
    - Click on "Test"
    - Click on "Save"
    - Exit VCDs
    The bluetooth is now active!
  1. Need help to code mmi with viseeo bluetooth mmi basic plus
    By Quattros in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-10-2011, 10:46 PM
  2. 3G MMI phone connection problem
    By Woody24 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2011, 06:59 PM
  3. Question BlueTooth and Ipood connection
    By Mini Mark in forum Golf MK5 - 2004 - 2009
    Last Post: 16-03-2011, 11:06 PM
  4. Audi MMI Bluetooth Phone connection problems
    By TH1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2010, 02:41 PM
  5. A6 Bluetooth connection
    By PatAvant in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-03-2008, 11:14 PM
