Thread: Tiptronic oil change !
Results 1 to 10 of 17
  1. Tiptronic oil change !
    Mar 2009
    Helsingborg, Sweden
    Hi All
    Just thought I would ask my local dealer out here in Sweden about changing the tiptronic gearbox oil in my Allroad .................... they've quoted me 1200 pounds.. yes thats correct 1200 GBP.
    So after picking myself up from the floor I thought I would ask you guys about prices in dear ol blighty, as it could be worth a trip?
    2012 VW CC 2.0 TDi
  2. Re: Tiptronic oil change !
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by piotrek View Post
    Hi All
    In Ireland my local mechanic charges €200 to do this job and he had all the equipment to reset the box too. I believe it costs £250-300 in the UK to have this done by a Audi Dealer
    Crazy price in Sweden
    VW CC GT 177 DSG
  3. Re: Tiptronic oil change !
    Jan 2011
    Kosice, Slovakia
    €295 in Slovakia, you need 5L of TToil (1L = €35). filter, seal=€80, €40 1 hour job,
    In AUDI dealer 500-600
    Aug 2006
    Thessaloniki, Greece
    Quote Originally Posted by Romio View Post
    Can you give me a link of the TToil?
    2006 Audi A6 Allroad 3.0 TDI Tiptronic
  5. Re: Tiptronic oil change !
    May 2007
    knee deep in clunge
    14 Post(s)
    Hi All
    Initial filling 9.8 ltr. 09L Oil change Fluid change interval (if required) → Maintenance tables
    Fluid change after repair (e.g. if oil pan has been removed): approx. 8 litres
    also there is a modified oil and gearbox flash update for shift issues part number of the oil blue, G 055 162 A
    standard oil and modified oil are both expensive (£25 per litre approx) per litre I would also recommend the oil pan filter replaced and the coolant replaced with G12 +++ to reduce any possible contamination of glycol
    some may be confusing the zf tip box with multitronic which is far less in cost to change the oil and has less capacity with a 40,000 service life change
    zf has no real life service interval for oil change unlike multi but I would advise it around 80,000 miles
  6. Re: Tiptronic oil change !
    Mar 2009
    Helsingborg, Sweden
    Hi A8,
    Thanks for your reply, I know you must have vast knowledge on this type of subject so I will now show as much as possible the breakdown I received from my local dealer, unfortunately it's in Swedish but I will translate as best I can.
    37551900 ATF pan removal/replacement £230
    37025550 ATF oil + filter change £180
    0150000 GF/Guided operation/adjustments/Basic settings £100
    G 060162A2 ATF oil 9.0lt @ £37.00 £333
    09L321371A Seal £36
    09L325429 Filter/sieve £37
    01V321376 Screw £7.0
    01V321379 Seal £1.8
    E07 Test drive £0.0
    Consumables £36
    VAT @ 25% (in Sweden) £243
    TOTAL £1216
    Maybe the numbers will mean something to you or they are a Swedish thing.
    Does the price seem about right or would it be worth a trip back to blighty to have it done?
    2012 VW CC 2.0 TDi
  7. Re: Tiptronic oil change !
    May 2007
    knee deep in clunge
    14 Post(s)
    they do indeed and is the correct process and billing to the oil change and filter plus adaptive basic setting road test
    unlike the other posts on this thread the dealer is correct and costing is also correct
  8. Re: Tiptronic oil change !
    Dec 2009
    southampton uk
    Thats impressive and I guess you wont find that v much cheaper anywhere at a dealers.How many miles on yours ?I was told the box is sealed for life on my A4 but at 115k had the oil drained and replaced with 5 ltrs at Audi for £159 just to see and it seems smoother.The old oil was black and research showed that the suppliers of the boxes recommended oil changes and thats why there is a filler plug!
    Aug 2006
    At my local Audi dealer I had the tiptronic fluid changed.
    5 lit fluid from Ravenol (same spec as OEM) €40.00
    Filter and pan with seals from Audi €80.00
    Labour work one hour €50.00 (total 8 hours as the temperature of the gearbox had to cool down)
    It was done at 135k kms and feels smoother. I was advised to change the oil again sooner in about 60k kms.
  10. Re: Tiptronic oil change !
    May 2007
    knee deep in clunge
    14 Post(s)
    5 lt is only half the capacity so you have been done over if your gearbox is a zf tiptronic gearbox that all 4f a6 including allroad use
  1. Oil change in Tiptronic gearbox
    By DGSdale in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-05-2011, 09:08 AM
  2. Tiptronic oil change
    By Shroud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-01-2010, 11:00 PM
  3. Tiptronic oil change
    By dawsose in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2009, 04:12 PM
  4. Tiptronic fluid change
    Last Post: 03-03-2009, 07:51 PM
  5. tiptronic/automatic oil change
    By beechboy_2000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-06-2007, 06:13 PM
