Thread: A6 2.5 TDI. ABS Failure!
Results 1 to 9 of 9
  1. A6 2.5 TDI. ABS Failure!
    Dec 2009
    Neath South Wales
    Evening all,
    Just been confirmed my ABS PUMP has failed! checked via VAG-COM and the message is....18259 Power trian data bus :missing message from ABS controller,
    P1851-35-10 Intermittent.
    Now my question is if I buy a replacement from a salvage yard then there seem to be many different variations of this unit. In that I mean, simular looking units with the same initial part numbers ie, 8E0 614 111 **, where the ** denotes a letter.
    So can I replace mine with a simular unit or must it match my number and letters exactly??? also there are codes underneath the electronic module, must these match exactly aswell????, the chances of finding a unit with both numbers, I find is more than difficult.
    Your help and knowledge is a great help.....
    Reagrds....Daidub
  2. Re: A6 2.5 TDI. ABS Failure!
    that is a difficult question as you say there are so many types of units and basically what fits one vehicle might not suit another,the VIN and PR codes determine which unit you need,can you supply the VIN and gearbox auto or manual and we can maybe find out what you can look for
  3. Re: A6 2.5 TDI. ABS Failure!
    london/ UK
    On the lucky side you will only need the electronic controller from the new/replacement pump and that can be done without touching the ABS pump or tampering with the brake pipes ! All you need is the pump with exactly the same part number then you remove the control unit by removing the 6 torx screws and replace the faulty on off the car... Do you have ESP or ASR ? If you have a FWD audi a6 i have a good working pump with ASR, if you have ESP it won't work unfortunately ! What's the pump part no ? Cheers.
  4. Re: A6 2.5 TDI. ABS Failure!
    Dec 2009
    Neath South Wales
    Hi Thanks both for the replys....
    My ABS pump code is 8E0 614 111 AH.
    While the actual ABS electronic module is 273 004 358
    If you have a suitable replacement please PM me......Cheers...Daidub
  5. Re: A6 2.5 TDI. ABS Failure!
    Dec 2009
    Neath South Wales
    OK, just checked what you ment by ESR & ASP, no I dont think my car has either, but not completely sure, ( how would I know ?) other than that its just a normal A6 SE 2.5 TDI ...Cheers
  6. Re: A6 2.5 TDI. ABS Failure!
    london/ UK
    If it's FWD then it should have a button on the dash (next to the cupholder) which sais ASR on it and when pressed it brings a triangle in a circle light on the dash. I have the same part off a car i break for parts...
  7. Re: A6 2.5 TDI. ABS Failure!
    Dec 2009
    Neath South Wales
    I'd like to thank Adamss24, through this medium, for guiding me through the endless possibilities of which ABS pump and module to purchase for my car, He really is a top man!!
  8. Re: A6 2.5 TDI. ABS Failure!
    london/ UK
    No problem Dave, as per our conversation, i will wrapp the controller and be on your way asap. Let me know when you'll get it ! Cheers,
    Chris.
  9. Re: A6 2.5 TDI. ABS Failure!
    london/ UK
    Quote Originally Posted by daidub View Post
    Actual part number for the ABS controller is 0 273 004 358, the bosch part number allways has 10 digits ! This will fit all cars VAG front wheel drive cars with Anti Slip Regulation ...
  1. Question ABS Failure
    By sheeshkabab in forum Early Passat Forum - Pre 97
    Last Post: 13-02-2011, 08:04 PM
  2. Bosch 5.3 ABS Module failure or is it?
    By AudiGaGa in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-01-2011, 03:10 PM
  3. VW ESP/ABS failure.
    By andy8442 in forum Chat - Anything with wheels
    Last Post: 03-12-2009, 11:57 PM
  4. ABS ECU Failure
    By ed a6 1.8T in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-07-2009, 10:56 PM
  5. Please Help A2 ABS warning light - possible ecu failure
    By OttoUnion in forum A2
    Last Post: 11-03-2009, 10:37 PM
