Thread: egr valve
Results 1 to 10 of 10
  1. Exclamation egr valve
    Jan 2009
    Birmingham
    36 Post(s)
    hi any help my car is very under powered on cold start only for a about couple of minutes
    im thinking it could be the egr valve clogged up the car is a audi a4 1.9tdi engine code BKE 54 plate 130500 on clock is it easy to clean or best to replace the part number is 038131501AD is this electronic operated because my car has a egr cooler on it as well but the egr valve looks totally different to normal vacuum operated ones thanks
  2. Re: egr valve
    i have never cleaned them only replaced them,and they are electronicaly operated, if the exhaust gass recirculation is not correct the engine management control light should light
  3. Re: egr valve
    Jul 2009
    liskeard cornwall
    i did mine a little while ago because i was told too by a mechanic who noticed oil on the side of the airbox intake pipe, to be honest he never said why i should do it but it would be a good idea because the wasted oil made the engine bay dirty,easy enough to do just need a little patiance and small fingers, i found 5mm of coke buildup inside the body and it took a while to clean out but worth the effort. refitted in no time, without exagerating the difference it made to the cars performance was incredible, better pedal responce and throttle responce, much much better
  4. Re: egr valve
    Jan 2009
    Birmingham
    36 Post(s)
    how easy it to do my car has a egr cooler on it aswell do you need any new gaskets to fit
    here is a pic of my engine see the area circled the wire has a cut in it how can i fix this. Cut and join the wires up should i dissconnect the battery first this wire is for the manifold flap could this be causing the underpower when cold thanks
  5. Re: egr valve
    I would have thought that fault would have logged a fault code,you can solder the wire.just make sure the ignition is switched off
  6. Re: egr valve
    Jan 2009
    Birmingham
    36 Post(s)
    do you think that wire is for the egr solinoid?
  7. Re: egr valve
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by trioptics130 View Post
    Is the EGR valve the circular shaped item on the left-hand side of the engine (at the top) with a plundger going into it?
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  8. Re: egr valve
    May 2008
    darlington
    Thats the anti shudder valve
  9. Re: egr valve
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by white.akita View Post
    Ah.. thanks. Where abouts is the EGR valve please?
    Toff.
    [ Past Audis:
    A6 S-Line 3.0
  10. Re: egr valve
    May 2008
    darlington
    the egr is next to the anti shudder valve, it is the round shiny thing with a vaccuum pipe going to it.
  1. Replies: 0
    Last Post: 08-07-2011, 04:48 PM
  2. EGR Valve
    By S-lineSingh in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-08-2010, 10:37 AM
  3. Please Help Egr valve again
    By Y90USF in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2010, 08:16 PM
  4. Question EGR Valve
    By cdti in forum Golf MK5 - 2004 - 2009
    Last Post: 23-01-2010, 03:09 AM
  5. Question EGR valve and EGR Flap
    By GT TDI PD 130 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2009, 12:16 PM
