Thread: Jacking points
Results 1 to 10 of 19
  1. Jacking points
    Jan 2010
    Chobham, Surrey
    I had to change a wheel yesterday due to the tyre being rather more worn than I'm happy with. My car has specially shaped rubber/plastic parts under the sill to take the jack. But it only seems to have them at the rear. Should there be some at the front too?
    Golf GT 140 TDI. Mods: RNS510
  2. Re: Jacking points
    Oct 2010
    Berkshire, UK
    No. If you look at the sills, there is a little triangle pressed into them (look carefully). Thats the part of the sill that is reccomended as a jacking point.
    46 Post(s)
    x2 on Josh's reply. there's points where it should be jacked at.
    On my old Mondeo I placed the jack in the wrong place and ended up piercing a jack sized hole through the floor! It was going to scrap anyways so didn't matter.
  4. Re: Jacking points
    Jan 2010
    Chobham, Surrey
    I couldn't spot the triangles no matter how hard I looked. At the rear there are definite plastic/rubber jacking points - do your cars have these? And if they do, do they have them at the front as well? My (Audi) jack has a barrel shape that contacts the car when jacking; the jacking point at the rear has a perfectly matching place for the barrel but there isn't one at the front on either side. Would some pictures help?
  5. Re: Jacking points
    Oct 2010
    leeds
    I have had a look at mine and honestly could not make heads or tails of it. If you do put some pictures on it might help. I will double check during proper daylight as it is getting a lil dark here to spot anything now.
    Raj
  6. Re: Jacking points
    Mar 2011
    Uk
    I had them jacking points on my 57 plate on all four corners of the sills. I have just checked on my 11 plate and that has them on all four corners aswell. Hope that helps
  7. Re: Jacking points
    46 Post(s)
    I'll try and take some pictures tomorrow on my 57 plate. The car is extremely dirty atm so Ill sort it out before taking them.
  8. Re: Jacking points
    Oct 2010
    Berkshire, UK
    X2.. though it is covered in the handbook
  9. Re: Jacking points
    Jan 2010
    Chobham, Surrey
    I read the handbook before starting. That showed me roughly where the 'triangles' indicating the jacking points ought to be. But I couldn't see them. Anyway, the rear jacking points are obvious, on my car. But it looks to me as though the front ones are not there, or at least the plastic/rubber bits are not present.
    Let's see if some pictures would help... (numpty picture linking skills coming up!)
    Jack:
    Rear jacking point (looking backwards towards rear wheel):
    Front jacking point (looking backwards from roughly the wheel arch):
    Last edited by AxeMurderer; 07-10-2011 at 03:09 PM. Reason: Hopefully I've got image linking sussed now...
  10. Re: Jacking points
    Mar 2011
    Uk
    looks like to me that they should be there but have either come off or been taken off at some point
  1. Question jacking points.....
    By mentalmackay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2010, 08:06 PM
  2. Jacking points
    By SMEG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2008, 04:52 PM
  3. Jacking points
    By jplawson in forum Golf MK5 - 2004 - 2009
    Last Post: 28-08-2008, 11:47 PM
  4. Jacking points on A3
    By jplawson in forum Audi A3 - Archive Topics
    Last Post: 24-08-2008, 03:47 PM
  5. Jacking Points
    By Ben in forum Chat - Anything with wheels
    Last Post: 13-10-2007, 10:51 PM
