Thread: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
Results 1 to 9 of 9
  1. Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Jul 2008
    Plymouth
    My brake pedal goes really hard when whilst driving. I give it a good rev and the brakes come back. Ive heard that there is a servo vacuum pipe connection at the firewall/bulkhead that collapses inside causing a loss of servo operation, apparently there is a modified part.
    Does anyone know the part number at all?
    It is a 2002 a4 tdi sport 130 bhp 6 speed.
  2. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Jan 2009
    Birmingham
    36 Post(s)
    Check you battery area plenum chamber for water the drain holes get blocked and the brake servo get water damage some people have up to a couple of inches of water there if no water check your vac lines to servo for damage
  3. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Mar 2009
    I had the same problem this time last year with my 2001 a4 tdi sport 130 bhp and had a few lucky escapes. It turned out that there is an issue with the plenum chamber filling up with water and not draining away. This resulted in the Brake servo filling up with water and causing the inside of the servo to corode. I contacted Audi here in Ireland and explained what was happening & it turned out that there was in fact a recall for this issue. They took my car and after examining the braking systems they concluded that there was in fact 'Consequental damage' caused from water entering the brake servo and in fairness to Audi they covered the replacment of the Brake Servo, hoses and Vaccuum pump plus all labour....So well worth looking into!!!
  4. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    I don't have the servo issue... yet... but my windscreen is getting very fogged up with the last few mornings, so I assume the drain plugs are blocked in my car. I might contact Audi here in Cork and see if I can knock free labour out of them. I could do it myself but if they're willing to do it for me all the better!
  5. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Jun 2008
    Beverley, east Yorkshire
    There is a recall to audi for the plenum chamber drain grommits so call audi and ask them to check if your car has been done, its all free by audi it only takes them a couple of minutes i think they just pull them out, in all fairness something that you could do at home
    A4 AVANT 2.5TDI SPORT QUATTRO
  6. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Do they just pull them out or replace them with anything new? If they are just pulled out, I wonder why they are there in the first place.
  7. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Jun 2008
    They are there to prevent dirt/water etc from going upwards into the plenum from the road. I dowt that will be as bad as leaving them in
  8. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Sep 2011
    Shannon, Ireland
    Hi there, JohnyIre! I was just wondering if you've contacted Audi in Cork and what outcome have you got? I'm in Ireland too and having similar problem with my 2001 A4 2.0.
  9. Re: Brake pedal goes mega hard whilst driving. Mega scary PLEASE HELP!!
    Not as yet, I have a window winder and small potential water leak to look at first. When it rains it pours!
  1. Please Help TDI 170 Sport Mega rebuild
    By rallymaneddie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2011, 12:30 AM
  2. Feeler for Southern region mega meet ?
    By Col in forum Shows & Events
    Last Post: 13-06-2009, 11:32 AM
  3. Mega-Wasp noise HELP!
    By Lethallizzy in forum Audi A3 - Archive Topics
    Last Post: 30-03-2008, 01:15 AM
  4. tune up or mega bodge
    By daxmatt in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-01-2008, 09:10 PM
