Thread: Understanding vw part numbers
  1. Understanding vw part numbers
    May 2010
    edinburgh
    hi there am trying to work out what the last part of the vw part numbers indicate.i know the first 3 numbers the model,and the next 3 the area of the car,but dont know where to find out the importance of the last section.
    In trying to track down the correct servo from my car,someone here kindly checked ecta?!and came up with 8E0612107E, vw dealer came up with 8EO612107J, and have been offered a good servo, part number 8EO612O15J!!
    Can anyone tell me the difference please, and if this servo i have been offered will fit?
    Alink to a site that i can put in a part number, and it lists the vehicles it will fit would be great.
    Most parts companies dont list this servo,it seems to be dealer only.Cheers Adam
    Ps just rechecked VAGCAT,and it coming up with 8E0612107 A!!3 variations now.
  2. Re: Understanding vw part numbers
    Feb 2010
    luton uk
    hi adam
    i had to replace my servo last year and searched ebay for the vw code and got a brand new one for my passat for just over 130quid maybe you could look there ?
  3. Re: Understanding vw part numbers
    Feb 2010
    luton uk
    hope the following helps you .
    VW Audi Seat Skoda Part Numbers Explained
    VWG (Volkswagen Group - VW, Audi, Seat, Skoda) part numbers may look confusing to the untrained eye but they do in fact tell you a lot about the part and even the car it is used on!
    This guide will hopefully provide eBay users with help in determining what the VWG part numbers mean and provide help when searching for part numbers for your car.
    The VWG part numbering system is a very logical sequence of numbers and letter, almost a language in itself. Once you understand how a part number is made up, you could almost guess what a part number would be!
    A typical basic VWG part number consists of a 9 digit block which in turn contains three seperate 3 digit blocks.
    A typical VWG part number looks like this: 1J0821021
    This can be broken down into the three 'lots' of the digits, i.e.:
    1J0 821 021 - Each group of three digits has a specific meaning:
    1J0
    N.B. All VWG cars have a specific chassis model code. Please see our separate MODEL CODES GUIDE for further information on the various VWG chassis models codes.
    1J is the model code for the car the part fits. In this case, 1J is a MK IV Golf.
    Sometimes when a part is different for left hand drive cars or right hand drive cars, the third digit will denote either LHD or RHD. A 1 would indicate the LHD and a 2 would indicate RHD. So:
    1J1 = a LHD specific MKIV Golf part
    1J2 = a RHD specific MKIV Golf part
    1J0 = Not specific to LHD or RHD models
    Another way the first three numbers are used is when the part is different for various body versions of the same car. i.e.:
    1H0 is MK3 Golf
    1H9 is MK3 Golf Estate
    3B5 is Passat Saloon
    3B9 is Passat Estate
    N.B. For certain engine and gearbox parts the first three digits of the part number do not denote the model code but the engine or gearbox the part is used on. An example of this is a part starting 02A is used for 02A gearboxes or a part starting 058 is for VWG 1.8 petrol turbo engines.
    821
    The next group of three digits 821 has two meanings.
    All VAG parts numbers are divided into 10 main groups and then into several sub groups. The main groups relate to the different vehicle assembly groups of the car as follows:
    Engine, Clutch
    Fuel tank and pipelines, Exhaust System, Air conditioning System
    Transmission
    Front Axle, Differential, Steering
    Rear Axle
    Wheels, Brakes
    Hand and Foot levers, Safety Covers
    Body
    Electrical Systems
    Extras, Accessories
    Our part number begins with 8. This means it belongs to group 8 which as we can see is 'body' and we refer to this number as the 'main group'. The 21 is the specific 'subgroup' of (8 ) body, and the subgroup 21 is always wings.
    The part number so far is 1J0 821 so we know already that is is a Golf MK IV wing!
    N.B. A part number that has a 98 as its 5th and 6th digit is a 'kit' part. i.e., it contains more then one part. An example of this is brake pads:
    1J0 698 151 M is a set of brake pads for a MKIV Golf.
    021
    The last three digits are the 'real' part number of every part.
    The last three digits in our example part number are 021. The number 021 has two meanings. 021 is the part number for a wing, also when a part is sided, i.e. left or right, the very last digit (1 in this case) denotes the side. An even number means right hand side, an odd number means left hand side. So in the example part number, 021 is a wing and the side it fits is the left hand side (being an odd number). This is normally always the case with only a few exceptions.
    So our part is a left side wing for a MK IV Golf!
    N.B It should be noted that left and right are always used when viewed from the rear of the car.
    For the UK the left (passenger) side is nearside and right (drivers) side is offside. An easy way to remember is nearside is nearest the kerb, hence, nearside.
    Frequently there will be a tenth digit after the 9 digit block which will be a letter. This refers to either the versions of this part i.e. if different models have different versions of the part, or if a part has been superseded, this letter will increase along the alphabet to indicate that a supersession has taken place.
    An example of this:
    1J3 831 055 H - This is a VW Golf IV 3 door left side door. Note the 3rd digit refers to the 3 door model and the 9th digit is an odd number so this denotes left side. The tenth digit 'H' denotes the version of the door.
    1J4 831 056 H - This is the right side front door but for a 4 door model. Note the third digit refers to a 4 door model and the ninth digit is an even number so it is right side. Again the 10th digit denotes the version of the door.
    Finally, some part numbers will have a further 3 digit block which denotes a colour or interior trim code. These can be parts for the body or interior of the car. An example of this is:
    1J0 807 217 C GRU - This is a front bumper for a MK IV Golf. Note the 807 refers to Main group 8 (body) and subgroup 07 (bumpers) the 217 is the specific number, the C is the version of the part number. The GRU is the colour code. In this example GRU denotes 'primed' so the bumper is supplied primed.
    Another example is:
    1J0 857 311 A 01C - This is an ashtray for a MK IV Golf. The 01C is the interior trim code for black trim.
    Remember that very often VWG will use parts across a range of cars. So you may be as likely to find a part number beginning 1J that originated on the MK IV Golf on an Audi A3 or a Seat Leon.
  4. Re: Understanding vw part numbers
    May 2010
    edinburgh
    yip thanks for that,just need to be sure which one is the right one for mine,getting conflicting answers,just rechecked vagcat again,and it got yet another letter on the end!really want to understand what all the different letters and numbers mean!!ta for replying,cheers Adam
    Ps just saw that bit you sent regarding the numbers,i saw that yesterday on an ebay ad? i think,thats how i sussed out what the first parts of the part numbers mean, but it didnt really clarify what the last bit, for my car specifically,means.will get there,thanks again for taking the time,cheers adam
  5. Re: Understanding vw part numbers
    Feb 2010
    luton uk
    no probs adam .
  6. Re: Understanding vw part numbers
    May 2010
    edinburgh
    bump!!surely someone on the forum must have some knowledge of part numbers??!! please.
  1. Part numbers
    By phil miller in forum Golf MK5 - 2004 - 2009
    Last Post: 22-08-2010, 02:27 PM
  2. where to get part numbers for a4 b5?
    By chrismaher2007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2009, 10:37 PM
  3. part numbers
    By MATTYBOY C in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2008, 02:32 PM
  4. part numbers? how to get them?
    By mrleeS3 in forum Audi A3 - Archive Topics
    Last Post: 23-10-2007, 05:20 PM
