Thread: engine noise - pulleys or bearing noise
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. engine noise - pulleys or bearing noise
    Aug 2009
    largs scotland
    54 plate 1.9TDi.
    I have a noise coming from the front of the engine which i suspect is coming from one of the lower pulleys. It is thereat low revs upto 1500 rpm and is particularly noticeable as the engine begins to take load. it is also aggravated if I turn the steering wheel whist moving off. What is the most likely source of the noise and should I worry about getting it fixed ?
  2. Re: engine noise - pulleys or bearing noise
    Sep 2008
    chester
    17 Post(s)
    It could be a few things,water pump bearing,idler roller(on the cam belt)but firstly check the alternator pulley one way clutch,get someone to hold the revs at 1500 and observe the aux drive belt tensioner see if its jumping all over the place,or with the engine off get a piece of wood about pencil size and put it through the alt opening in the front and see if it free wheels one way (from recallection I think its anti clockwise).
  3. Re: engine noise - pulleys or bearing noise
    Aug 2011
    Cork, Ireland
    It sounds like it is your aircon pulley. Down low on the passenger side of the front of the engine. check to see if you an move it with your hand. A comin problem.
  4. Re: engine noise - pulleys or bearing noise
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by nevo View Post
    I'm with Nevo, be very surprised if it's not the alternator pulley.......about £190 done at the main dealer. If you want a laugh, ask to watch them do it and see how far off they are on the labour estimate. They told me "about an hour" and it took them 2.5 ;-)
    Bonny Scotland
    Most importantly don't leave it too long before sorting it, as Crasher pointed out in the B5 forum - a snapped aux belt can take the timing belt out.
    Frank
  6. Re: engine noise - pulleys or bearing noise
    Jul 2007
    somerset
    8 Post(s)
    Hi, just done mine today, bought a genuine alternator pulley from TPS which was £88.00, removed the alternator from the car and a mate of mine had the special tools to remove the old pulley and replace with the new one.
    the old one was seized solid and causing a clunk noise on start up and a rumbling noise when pulling away on low revs, also the alternator tensioner was wobbling around a lot. Quite an easy job to do as long as you have the right tooling. By the wat, the pulley is very tight and we needed a breaker bar to get enough leverage to undo it.
  7. Re: engine noise - pulleys or bearing noise
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    The genuine INA clutch/pulley assembly I bought for a 140A 1.9TDI Alternator for a MK5 Golf was only about £20 from GFS ( about 4 months ago).
    Skoda Octavia II SE 1.9PD TDI
  8. Re: engine noise - pulleys or bearing noise
    Jul 2007
    somerset
    8 Post(s)
    God that sounds cheap, mine was a genuine Audi part, Part number S 06B 903 119D (the "S" means the part has been superseeded) it was also made by INA. Proves how much audi are making i suppose, i did see some cheap ones on the bay but the quality is probably poor. As i did the job myself and hence no labour costs i don't mind buying genuine parts as there is a 2 year guarantee and i also have a trade account with TPS. Perhaps i should have done some more homework, although i did post on here where the best place to buy one from was and no one replied, so for piece of mind i bought genuine from audi. At least i know its a quality item that should last as long as the original one did (although that was only 79K).
  9. Re: engine noise - pulleys or bearing noise
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Maybe the Audi part is different. I did check the INA bearing/pulley P/No.(not VW P/No.) on a genuine VW part ( about £50) and then found that the GFS was exactly the same.
  10. Re: engine noise - pulleys or bearing noise
    Jan 2009
    Birmingham
    36 Post(s)
    I've got a slight rattle coming from the engine at idle but soon as I put the aircon on it goes any one had this problem was reading it could be the air con pulley bolt loose
  1. Mk5 GTI bearing noise ???
    By smwgti in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2017, 03:58 PM
  2. Humming noise - wheel bearing?
    By wj209980 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-12-2010, 07:40 PM
  3. Front disc or bearing noise?
    By freddyuk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-10-2010, 09:13 PM
  4. Question bearing noise
    By shanghaining in forum Polo - Derby - Lupo - Fox
    Last Post: 01-02-2009, 11:47 AM
  5. Question Touran Bearing Noise
    By Witty in forum Touran - Sharan - Caravelle
    Last Post: 29-07-2008, 07:54 AM
