Thread: Blue Dash lights..How easy to change?
  1. Blue Dash lights..How easy to change?
    Jun 2008
    Has anyone changed the blue lighting as found on the instument dials of my 55 plate B5.5?
    I much prefer the soft red glow that is present on the radio/cd section and as was on my old A3.
    I would hope it would involve just swapping bulbs but perhaps thats a bit naive of me.
    D
  2. Re: Blue Dash lights..How easy to change?
    Jul 2010
    battle
    Hi I had to change the bulbs on my A4 and it was a very easy job, it took approx 15 minutes to do and that included putting the new bulbs into the dash as well as taking the dash out and reconnecting.
    I just bought new orange ones myself, the reason for changing was that I couldn't see the mileage on my car, I think if its anything like the audi then you will have to buy about 10 bulbs just to be on the safe side, but they are very cheap, I got mine from auto bulbs direct.
  3. Re: Blue Dash lights..How easy to change?
    Jun 2008
    Vince thanks for the reply, i'll check that out.
    D
  4. Re: Blue Dash lights..How easy to change?
    Apr 2009
    Quote Originally Posted by vince70 View Post
    !5 minutes is very good, considering the air-bag, steering-wheel, bits of trim
    and instrument cluster need to be removed and replaced.
    Regards
    Jim
    Still Crazy After All These Gears
  5. Re: Blue Dash lights..How easy to change?
    Jul 2010
    battle
    If your taking the steering wheel and airbag off your obviously doing it wrong.
    You lower the steering wheel to the lowest level and unclip the steering wheel surround, then undo the two screws that hold the dash in position and pull the dash out, it takes about a two minutes.
    I really cant work out why you would take the steering wheel and airbag off.
    Ps that is the way I did it and someone put a post up on here on how to do it maybe its different on the Audi to a VW.
  6. Re: Blue Dash lights..How easy to change?
    Jun 2006
    UK, Mids
    TBH, I thought the LEDs were soldered onto the PCB as there are no bayonet bulb holes on the back as you see on older cars..
    EDIT, yes I found a photo of the PCB and they are SMDs soldered on.
    Audi A8 - 2015 - 3.0TDI
  7. Re: Blue Dash lights..How easy to change?
    Apr 2009
    Don't knock it till you try it : )
    Regards
    Jim
  1. Please Help Reverse Light Switch - easy to change?
    By JohnL1998 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-11-2008, 08:36 PM
  2. Please Help 1.8t golf mk engine change how easy are they
    By Rikkgti in forum Golf MK4 - 1999 - 2004
    Last Post: 19-05-2008, 10:15 PM
  3. How easy is it to change a wing?
    By Androo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 03:05 PM
  4. How easy is it to change the front speakers?
    By Coastie in forum 80 - 90
    Last Post: 29-10-2007, 07:31 PM
  5. Is it easy to change rear brakes pads on A3
    By A Tdi in forum Archive posts
    Last Post: 01-09-2007, 06:02 PM
