Thread: Aftermarket stereo harness - Illumination Wire
  1. Aftermarket stereo harness - Illumination Wire
    Mar 2009
    York
    After receiving all the gubbins to install my aftermarket stereo, just inspecting the ISO wiring harness and there are two leads - one the 12v ignition is self-explanatory, the other - an orange dash illumination wire is less so.
    Is there any wire I can splice into, that would provide the relevant signal for this? Not sure where the illumination wires sit in the B6 passat.
    Thanks for any help, otherwise I'll just leave this taped up like a lot of other people do.
    Paul
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  2. Re: Aftermarket stereo harness - Illumination Wire
    Mar 2009
    York
    apologies...
    a little digging on google shows that the wire will be redundant due to the canbus technology. For things like this to work I need a £90 kenwood canbus adapter. Not exactly worth it.
    Thanks anyway.
  3. Re: Aftermarket stereo harness - Illumination Wire
    Up North
    Or you could put a scotch lock into the supply for the illumination ring on the cigar lighter socket. That's what I did and it supplies enough current to switch the high/low display on the radio.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  4. Re: Aftermarket stereo harness - Illumination Wire
    Mar 2009
    York
    Easy to get to?!
  5. Re: Aftermarket stereo harness - Illumination Wire
    Apr 2010
    Ashford, Middlesex
    Quote Originally Posted by patomlin76 View Post
    Easy to get to?!
    Yes mate - have a look at this guide which is for the installation of the footwell LED's; the wire you want to connect to for stereo illumination is the very same one.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  6. Re: Aftermarket stereo harness - Illumination Wire
    Mar 2009
    York
    thanks! looks easier to get to than I thought. Not got small hands but will do my best to do it from behind the centre trim, rather than remove the centre console gaiter and ashtray...
  1. illumination wire for headunit b6 A4
    By audisingh in forum In Car Entertainment
    Last Post: 10-01-2010, 12:13 AM
  2. illumination wire on a 6 disc loader
    By jamesey in forum In Car Entertainment
    Last Post: 01-04-2009, 07:44 PM
  3. Illumination Wire location on Concert II on A3 (Sept 2002)
    By Antmaz in forum Audi A3 - Archive Topics
    Last Post: 25-01-2008, 03:37 PM
  4. Any help on how to connect illumination wire to 6 disk in dash changer?
    By dragon100 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-10-2007, 09:47 AM
  5. sensor wire enters the harness by the positive battery lead.
    By parts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-08-2007, 05:56 PM
