Thread: 2007 Passat 170 BHP BMR engine code, cut out now wont start
Results 1 to 8 of 8
  1. 2007 Passat 170 BHP BMR engine code, cut out now wont start
    Oct 2009
    Newbury
    Hi there i have just done a service on this passat, road tested the vehicle for 30 miles to try to get the DPF to regenarate, it has 30% pressure and is realy smelly when stationary. Came back to the work shop vehicle was left idling and it just cut out. Tryed to restart, vehicle wouldnt fire, ECU light came on & said workshop on the dash.
    Plugged the vehicle in using autodiagnos, snap on verus & carman scanner all bring up the same codes.
    05399 Unknown componant interruption/short to ground briefly occuring DTC (05399 103)
    You delete this codes as soon as the ignition is switched it comes staright back.
    We found some badley corroded wires in the fuse box, the vertical fuses that are the main power suply wires, we cleaned all of them and replaced one bad terminal.
    I then replaced the injector wiring loom i have done many of these the last few years so thought i would try this first.
    I checked all the glow plugs & injectors resistances, all glow plugs working all injectors resistance the same. does anyone have any idears
  2. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    130 Post(s)
    1972 Post(s)
    A failed injector, I have done two this week. Disconnect each injector one at a time until it starts and that will identify the failed injector for you. When running the engine with the cam cover off, a jet of oil will spray at the head to about ten feet high so put the cover back on each time, not bolted on, just put back on.
  3. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    Mar 2009
    Sleaford, Lincs, UK
    Euuugh, failed injector on the 1st 170 on this site?
    There's me thinking 170's were immune!!
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  4. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    130 Post(s)
    1972 Post(s)
    , err-no....
  5. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    Mar 2009
    Sleaford, Lincs, UK
    , err-no....
    Doh!
    Crasher do you do cambelts and long life services at c&r??
    Deep Pearl Black
  6. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    130 Post(s)
    1972 Post(s)
    We certainly do but for prices you would need to speak to Roy or John in the ofice, I hide in my workshop.
  7. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    Mar 2009
    Sleaford, Lincs, UK
    Ahh no worries, thought it was your place! You seem military friendly looking at your signature so thought I'd ask and hope for military discount
    Deep Pearl Black
  8. Re: 2007 Passat 170 BHP BMR engine code, cut out now wont start
    130 Post(s)
    1972 Post(s)
    It is half my place, John is my buiness partner but they keep me chained up in the back so as not to scare the customers away.
  1. VW Passat - Snapped cambelt VW Passat TDi BMR Engine
    By a1carparts in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-09-2011, 01:32 PM
  2. golf 170 bmn into passat bmr?
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2010, 12:55 PM
  3. engine swap passat 170 bmr
    Last Post: 21-03-2010, 09:13 PM
  4. A6 2.6 V6 wont start after rev limiter cut out engine
    By Andi A6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-01-2010, 01:00 PM
  5. cut out and wont re-start!!
    By b5wagon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2009, 09:05 PM
