Thread: Audi RNS-e Navigation is lost...
Results 1 to 10 of 13
  1. Audi RNS-e Navigation is lost...
    Aug 2010
    Saffron Walden UK
    My built in Audi Nav unit (RNS-e) in my 2005 S4 has gotten lost....
    It has worked fine since I had the car, but yesterday going to RIAT it never latched on to a signal and so had no idea where it was.
    Couldn't find a reset button or anything similar.
    Any ideas?
    Thanks in anticipation!
    ____________________
    Audi A8 3.0 TDi SE
    Gone... Audi S4 Cabriolet / VW Passat Estate / VW Golf / VW Passat Saloon / Audi 80 Sport / VW Scirocco
  2. Re: Audi RNS-e Navigation is lost...
    May 2008
    Could be a failed GPS antenna. Check how many satellites the unit is recieving.
    If it has gone, replace it with one from Ebay for £10.
  3. Re: Audi RNS-e Navigation is lost...
    Aug 2010
    Saffron Walden UK
    Thanks, its receiving none according to the Nav Info.
    How easy is replacing the antenna?
    Audi A8 3.0 TDi SE
  4. Re: Audi RNS-e Navigation is lost...
    May 2008
    To replace the original Audi item - tricky and expensive as you'd need to remove a lot of trim to get it out.
    Buy one of these from Ebay and stick it under the dashboard behind the glovebox. I've done this to mine and it works 100%. Takes ten minutes to fit.
    http://cgi.ebay.co.uk/NAV-GPS-ANTENN...item4cf60e5868
  5. Re: Audi RNS-e Navigation is lost...
    Aug 2010
    Saffron Walden UK
    Ah right, thanks - looks cheap enouhgh... presumably has to plug in to back of the Nav unit? Sorry if this is obvious, I've never had the need to pull teh dash apart..
    Audi A8 3.0 TDi SE
  6. Re: Audi RNS-e Navigation is lost...
    May 2008
    Yes, just plugs in at the back. Only goes on one way so you can't go wrong. You'll need 4 removal keys to get the unit out of the dash. Available from Audi, Halfords, Ebay etc etc.
    Just drop the glovebox out (a few 8mm bolts) and stick it under the dash (under a plastic section of dash not metal) and test it before you put the glovebox back up. It's very easy to do - Don't pay someone to do it.
  7. Re: Audi RNS-e Navigation is lost...
    Aug 2010
    Saffron Walden UK
    OK - thanks again. I'll take a look.
    Regards
    Audi A8 3.0 TDi SE
  8. Re: Audi RNS-e Navigation is lost...
    Aug 2010
    Saffron Walden UK
    Right, next problem, how do I get the Navigation head unit (a double din thing) out? I guess I need some kinda unique Audi tool...?
    Audi A8 3.0 TDi SE
  9. Re: Audi RNS-e Navigation is lost...
    May 2008
    Read post #6 that I made above. You need 4 removal keys, available from the sources I mentioned.
    Nov 2010
    Kent, UK
    You could try resetting the unit - turn it on then press and hold the Info and Setup buttons for more than 10 seconds.
  1. Please Help Audi Navigation plus (RNS-E)
    By Neil Young in forum In Car Entertainment
    Last Post: 06-06-2011, 05:07 PM
  2. Enable bluetooth on RNS-E DVD Navigation (Audi Navigartion plus 2007)
    By 519ryan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-04-2011, 08:45 AM
  3. Help with RNS Navigation Plus
    By david2 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-12-2010, 09:42 AM
  4. Audi RNS-E Navigation Manual (electronic format)
    By vwcamperman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2009, 07:29 PM
  5. Not sure what CD goes in my RNS Navigation system.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 11:26 AM
