Thread: A6 tdi quattro high idle 1100rpm
Results 1 to 10 of 11
  1. A6 tdi quattro high idle 1100rpm
    Jul 2011
    Cheddington
    I have recently bought a 99 A6 2.5 tdi and when first starting the car from cold it idles at 750-800 rpm which is normal. After 5 mins of driving, or just sitting at a junction for example the revs will go from 750-800 rpm to 1100rpm. The engine will then idle at 1100rpm for the remainder of the journey. (It's a fairly high miler at 178k)
    Any thoughts as to what could be causing this?
    I am going to change engine oil, filter and oil temp sensor in sump (oil temp always reads 0) as previos owner did 15k without changing it. Car has limited/next to no history.
    Thanks in advance
    James
  2. Re: A6 tdi quattro high idle 1100rpm
    Ayrshire, Scotland
    18 Post(s)
    does water temp sit bang on 90deg?
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: A6 tdi quattro high idle 1100rpm
    Jul 2011
    Cheddington
    Yes, the water temp goes up to 90 and just stays there. I havent scanned it, which I can do at a mates. Only things I can think of is air leak, MAF or ecu compensating when car gets to certain temp.
  4. Re: A6 tdi quattro high idle 1100rpm
    Ayrshire, Scotland
    18 Post(s)
    what is the engine code? 3 letters found in the logbook & in the spare wheel well
    My AKE has 2 temp sensors, one for the dash, sits on top of the engine, and there is one on the low pipe to/from the radiator, I think it is for the ECU, get a scan done and you may be able to check engine temperatures in the measuring blocks to see if its it faulty
    Andy
  5. Re: A6 tdi quattro high idle 1100rpm
    Jul 2011
    Cheddington
    Quote Originally Posted by bagpipingandy View Post
    Andy
    This is really starting to p me off, I have replied to this thread 3 times over the past week and it never posts up!! It's an AFB engine. The soonest I can get a scan done is on the 13th Aug when im back from hols.
    I got a water level beep yesterday so the water has gone down after 800miles.
    Thanks for advice.
    James
  6. Re: A6 tdi quattro high idle 1100rpm
    london/ UK
    Change the coolant temp. sensor. It has dual outputs 2 pin for the gauge and 2 pins for the ECU. In your case the ECU part is not working well and computer defaults to high rpm as it thinks that outside is very cold and tries to warm-up the engine. Get a new seal as well !
  7. Re: A6 tdi quattro high idle 1100rpm
    Douglas Isle of man
    I had a very similar problem. 2 minutes after starting the idle speed went up to 1200 rpm.
    Its not nice trying to hold the car back. I replaced the temp sensor and resetted the fault. I have a good 740 rpm idle and the problem has never come back.
    I have a number of problems. One down a couple to go or may be one to sort all.
    Good luck
  8. Re: A6 tdi quattro high idle 1100rpm
    Douglas Isle of man
    Hi James. Have you got anywhere with the problem. I bought a sensor from Ebay for about 8 pound. It was a genuine part.
    Its easy to replace. It took 5 minutes.
  9. Re: A6 tdi quattro high idle 1100rpm
    Jul 2011
    Cheddington
    Thank you everyone for the v helpfull answers. I really appreciate it! I have just returned from holiday and I am going to sort this problem out asap. So the sensor I need is the 4 pin sensor as here on ebay:
    http://www.ebay.co.uk/itm/AUDI-COOLA...item27b45c0d88
    Thanks very much! James
    Douglas Isle of man
    Yes that's the one. It's an easy job. Let us know how it goes.
  1. Intermittent high idle
    By gtitdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-09-2017, 11:45 AM
  2. Please Help High Idle Speed
    By manclad in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2010, 08:28 PM
  3. 2.5 TDI Quattro Manual Idle too fast
    By schomosport in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 31-10-2009, 01:48 PM
  4. Passat High Idle.
    By tommyk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 08:34 PM
  5. Question Engine Idle speed sticks 1100rpm sometimes
    By madbonky in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2009, 06:26 PM
