Thread: Where would I attach a negative jump lead to
  1. Where would I attach a negative jump lead to
    London
    It seems clear that I would connect the positive jump lead to the bolt thingy under the location which bears a red + sign which is under the midlle "mesh" cover above the plenum chamber i.e. near the bulk head and next to the brake fluid top up reservoir. All this is only visible once one removes the middle mesh cover.
    Er however, where would I connect the negative jump lead to ? I cannot understand the manual. Do I have to lift off the plastic engine cover to connect the negative jump lead ?
  2. Re: Where would I attach a negative jump lead to
    Jan 2009
    Essex
    This is from the manual
    Switch off all electrical equipment. Remove the ignition key.
    Open the bonnet
    Open the red cap on the positive terminal Fig. 1.
    Connect the charger cables as specified to the jump-start terminals (terminal with red cap = "positive", terminal with hexagon = "negative").
    Now connect the battery charger to the mains and switch on.
    After charging the battery: switch off the battery charger and disconnect the mains cable.
    Now disconnect the charger cables.
    Refit the red cap onto the positive terminal.
    Close the bonnet
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: Where would I attach a negative jump lead to
    Berkshire
    Any decent exposed bit of bare metal that the jump lead will happily clamp to I guess ....
  4. Re: Where would I attach a negative jump lead to
    Jan 2009
    Essex
    That's not advised on modern cars. I don't know the reasons but I believe the amount of circuitry means it's more risky than it used to me.
    0 0 1
  5. Re: Where would I attach a negative jump lead to
    Quote Originally Posted by headache56 View Post
    ...where would I connect the negative jump lead to ? I cannot understand the manual.
    Connect the negative lead to the negative bolt 'thingy'. You'll notice that, as in Scotty's picture, one of the suspension top mount bolts is longer than the others. Look more closely and it has a minus etched into it. This is your negative thingy.
    MY2009 A4 Saloon 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Convenience Key, Sunroof, Adaptive Lights, Anti-dazzle Folding Mirrors, Rear Sun Blind, Heated Full Leather with Memory, Storage/Light Packs, Audi Hold Assist, Adaptive Cruise Control, Parking System Advanced, Privacy Glass, Rear Airbags, TPMS. MMI 2G with B&O Sound System, DAB Radio, DVB TV, AMI and Bluetooth Phone prep High with Privacy Handset.
  6. Re: Where would I attach a negative jump lead to
    London
    Thanks guys, once you pointed me in the right direction it was easy. er its always easy when you know the answer.
  1. Please Help Re-attach rear view mirror
    By A1exp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2018, 11:29 PM
  2. Leaving negative feedback on Ebay
    By Captain Answer in forum Chat - Completely Off Topic
    Last Post: 13-11-2009, 11:42 PM
  3. negative deviation????power loss
    By dufferum in forum Audi A4 - Archive Topics
    Last Post: 14-12-2007, 08:03 AM
  4. Negative Battery Lead
    By Alpinist in forum Passat - Archive Topics
    Last Post: 14-10-2007, 07:45 PM
