Thread: Econ mode will not turn off
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. Econ mode will not turn off
    Apr 2006
    I have recently bought an Audi A4 TDI SE 1.9 first registered in December 2002 and cannot get the climate control out of Econ mode. Pressing Econ, Auto or any other combination of buttons does not remove the red light from the Econ button?
    Any ideas on how to fix this? Thanks very much.
    May 2006
    Believe can be a number of things worst case compressor, or clutch on compressor, best case no gas.
    Know this only from my research on other forums as I have the same problem - Have you cured yours now?
  3. Still not fixed
    Apr 2006
    No, still the same problem!
    I have booked the car in to an Audi garage in a couple of weeks for a diagnostic test.
    May 2006
    Have just had diagnosed mine has come up as the high pressure switch @ £35.00 or so. Good luck with yours
  5. Follow up
    Apr 2006
    This issue is now resolved.
    Needed a replacement pressure sensor, £100 fitted by an Audi dealer.
    Jul 2006
    My aircon was getting warmer so at 5 years old I got it regased. That worked for a day then it just blew warm and climate panel flashed on switch on. The evaporator unit (inside the car) had ruptured and lost the gas. Got a replacement from German and Sweedish for £120, VAGCOM for £160, and a weekends work got it fitted. Regassed and has worked ace eversince.
  7. Help Help Help ! ! ! ! !
    Feb 2007
    my econ led does not go off, my compressor is ok, compressor clutch is ok, pressure switch is ok and my pressure sensor is also ok. wht do i do now, plssss somebody help me.
  8. Hmmmm
    Feb 2007
    Hi All
    I have the same prob on my 2003 S3 no matter weather the econ light on or off always the same (warm air)
    Please could u tell me where to find the pressure switch would help alot
    Thnx a Stack
    Feb 2007
    High this is the same kind of problem I have had I have been advised to get the gas checked then get the fault codes read if the gas level is ok. The difference with mine is that sometimes the econ button comes on its own then will not turn off and other times system works fine. On my travels investigating this I found a company who can reconidition air con controls for around £100+ p.p. or test for @ £30+p.p. they are called B.B.A. reman based ingillingham kent has anyone used them? When mine is fixed I will post what was needed good luck all!!
  10. Talking Econ mode stuck on problem fixed
    Feb 2007
    As stated in my other post this turned out to be the high pressure switch. My car is now fixed and Climate is working perfect.
  1. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  2. Radiator fan won't turn off!
    By roba75 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-11-2007, 05:18 PM
  3. Econ permanently on?
    By defero31 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2007, 12:51 PM
  4. Help Me Turn Up My Boost!
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-09-2006, 10:23 PM
  5. ECON(aircon) Not blowing out cold air....
    By swarze77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2006, 05:07 PM
