Thread: Allroad Suspension up down switches died.
  1. Allroad Suspension up down switches died.
    May 2009
    ireland
    Got into my car the other day to find that none of the suspension switches lit up. When you press any of the 2 switches nothing happens-- Completly dead. No lights lit up in them. Also the switch for the ESP does not work either. This should light up in the dash when switched off but nothing. Are all these run on a main fuse, relay or control board.
    Anyone seen this before. - getting the following faults but dont it would cause this problem.
    34 - Level control system
    4Z7 907 553G ------------
    - 2C1A1 D052
    Code 25500
    Dealership number 385
    2 Trouble code detected?
    Any help.
    Could this be a main fuse as i have checked others
  2. Re: Allroad Suspension up down switches died.
    May 2009
    ireland
    Actually looking at the printout again it appears that there is a communication problem with the module.
    Would this imply a blown fuse??
    There is this module physically located.??
    01310 049
    Level Control System Control Module -J197
    No communication
    Status: Intermittent
    No environmental conditions stored
  3. Re: Allroad Suspension up down switches died.
    Ayrshire, Scotland
    18 Post(s)
    what are you scanning with?, what are the actual codes "2 trouble code detected"?
    i assume it is not VCDS you have scanned with.
    there are fuses:
    1.fuse S7 (fuse in fuse box)
    2.Fuse S110 self leveling suspension, 40A
    location 23 behind the storage - driver's side, (not exactly sure where)
    3.Fuse S5 (in fuse box)
    check the fuses 1st and get the codes confirmed
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Allroad suspension compressor
    By 27allroadpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 02:09 PM
  2. Tdi died and wont start,battery light came on before it died..
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2010, 05:44 PM
  3. Allroad suspension
    By adamdavis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2009, 10:17 PM
  4. Allroad suspension
    By murdochcg in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-06-2009, 11:15 AM
  5. What's the A6/Allroad Air Suspension Like?
    By ChillOut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2009, 09:53 PM
