Thread: S4 brakes
  1. S4 brakes
    Dec 2010
    cheltenham
    Got a facelift quattro and want to fit the S4 brakes to it, does anyone know if it's a straight swap or whether I need to change the upright too.
  2. Re: S4 brakes
    Wirral
    AFAIK looking at ETKA, you shouldnt have to change the uprights as both the S4 & AJL engined Quattro's have the 82mm Wheel Bearing housings vs the 75mm housings of lesser models. Hopefully somebody can confirm this.
  3. Re: S4 brakes
    Dec 2010
    cheltenham
    I was chatting with the a guy from my local audi specialist and he was checking numbers for me and it does have the 82mm housing but the part numbers were different between the A4 and S4 (iirc it was an extra letter at the end of the part number)
  4. Re: S4 brakes
    Wirral
    8D0 407 257 AL & 8D0 407 258 AL are the 75mm left & right respectively
    8D0 407 257 AM & 8D0 407 258 AM are the 82mm left & right respectively.
  5. Re: S4 brakes
    Jul 2008
    stoke on trent
    the caliper mounting holes are spaced differently so the s4 brakes wont bolt on
    you would need uprights but the quattro outer cv's will fit (they do on my 1.8tq not sure about others)
    the calipers are also very wide so might not clear some alloy wheels
    the other alternative is audi TT/S3 caliper carriers which bolt straight on and allow 312mm discs to be used with original calipers
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  1. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  2. Brakes Help!!
    By dieselal in forum VCDS - General Questions
    Last Post: 11-04-2010, 01:08 PM
  3. brakes
    By rotter766 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2008, 07:36 PM
  4. Brakes....
    By kenhodgson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2008, 01:12 PM
  5. Upgrade A6 brakes to S8 brakes
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 10:15 PM
