Thread: parking sensors
  1. parking sensors
    Mar 2010
    london uk
    I'm thinking of the parking sensor for a while as visibility in the back of the passat is not to good.I've found this on the internet http://www.parkingdynamics.co.uk/Veh...g-Dynamics-PD1 ,has anyone tried it? seems a lot more simple as you don't have to drill the bumper.Cheers for any advice
  2. Re: parking sensors
    gireada2005
    I have no experience of the product mentioned, but I do have rear parking sensors (badged by VW, but actually made by Cobra) which I fitted myself.
    If you're nervous about drilling holes in your bumper, then the Parking Dynamics system may be attractive. however, from the description of the product I'm not sure that the installation would actually be any quicker. You will have to remove the bumper (large and unwieldy) to fit the PD sensor strip. Although you have to drill 4 holes to fit the more common ultrasonic sensors, you don't need to remove the bumper. Otherwise, the installation work for the the two types of system will be similar.
    Just my two pennyworth....
    Mikecb1
  3. Re: parking sensors
    Jan 2010
    Lisburn, United Kingdom
    I masked my bumper off and drilled the holes. Was easy as! Total instal was about 2 hours tops and it makes a huge difference.
    This is the picture I took when I installed mine. Mark the masking tape with a pencil so you can have the exact place to drill the holes. Measure twice drill once! Then using a coat hanger fed the cable through the rubber grommet into the boot. Easy!
  4. Re: parking sensors
    Jan 2010
    iPhone double post
  5. Re: parking sensors
    Apr 2007
    France
    12 Post(s)
    If, despite g-black's comprehensive instructions, you still don't want to drill, get some Meta Targa sensors. The holder simply fits behind the number plate, the wire goes through the grommet that g-black refers to, connect it to the reverse light wire and that's it. They work surprisingly well, I know, I've got some.
    1996 Laguna 2.2D
    1977 MGB roadster
  6. Re: parking sensors
    Dec 2008
    Sale
    Quote Originally Posted by gireada2005 View Post
    A friend of mine fitted that type (not sure if exactly the same) to his Boxter as he didn't want to drill the bumper, he reckons they are very good and has since fitted them to his sisters car and a mates.
    I use these and they work fine http://cgi.ebay.co.uk/Meta-Number-Pl...item483de35710
  7. Re: parking sensors
    Mar 2010
    london uk
    g-black your sensors finished work looks very nice ,have you used original vw sensors or other brands from the market?i've read somewhere on the forum that they got some issues with the original ones.from where you are taking the power,cheers for all of your inputs
  1. Question Parking sensors
    By Leigh1972 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-04-2011, 05:19 PM
  2. Parking Sensors
    By bora23 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2011, 04:08 PM
  3. Parking sensors
    By mikeaggy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-12-2009, 07:49 PM
  4. Parking sensors
    By winchman in forum Bora - 1998 - 2005
    Last Post: 08-11-2008, 09:34 PM
  5. Parking Sensors
    By mhurer in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-10-2008, 08:49 PM
