Thread: A3 2007 symphony stereo not working
  1. A3 2007 symphony stereo not working
    Suddenly, the Symphony stereo in our A3 2007 2.0TDi is not working. There is no power to the unit, so won't switch on or eject a disc. The unit doesn't light up at all with the lights/ignition on either.
    I've have checked fuses F8 & F18 in the engine bay for the sound system and the amp and they are both good. I have removed both fuses and re-inserted them, to no avail.
    Any clues would be greatly appreciated.
    Regards,
    Steve
  2. Re: A3 2007 symphony stereo not working
    Southern County Softy
    20 Post(s)
    you might find the fuse on the back of the unit has blown.before removing the head unit
    try disconnecting the car battery for 10mins to force a system reset.
    A4 2.5 tdi QS (mapped)
  3. Re: A3 2007 symphony stereo not working
    Tried the battery force reset to no avail and have also removed the head unit to find the fuse was all good. Replaced it to be certain, to no avail.
    Apparently the unit came on briefly the other day...........if you can work that one out, I'm all ears!!!
    Regards,
    Steve
  4. Re: A3 2007 symphony stereo not working
    20 Post(s)
    sounds like a loose connection somewhere.
  5. Re: A3 2007 symphony stereo not working
    May 2015
    berkshire
    Hello,
    I am.also.having the same.problem. No power.to stock or after market head unit. I really need some help . I checked the fuses.and still dead. Any ideas of what wires i should check?
  6. Re: A3 2007 symphony stereo not working
    Crikey, that was a while ago....it was definitely something in the unit, quite possibly a fuse or other component. I took it to a fix it at home guy and it cost not a lot £20 or £30, nothing major. The hardest bit is finding the fix it guy. Consider a back street hifi outfit, they might do it too. Good luck
  1. fabia 2007 symphony cd player stops
    By treddall in forum Fabia
    Last Post: 15-04-2009, 02:53 PM
  2. Question audi symphony stereo
    By toptek in forum In Car Entertainment
    Last Post: 24-08-2008, 08:32 PM
  3. No AM on symphony stereo
    By oscardog in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-07-2008, 08:30 PM
  4. Help - Removal Of Symphony Stereo
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2008, 08:30 PM
  5. A4 Symphony Stereo
    By JRW1979 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-10-2007, 02:00 PM
