Thread: Control Module for All Wheel Drive (J492) Error
  1. Control Module for All Wheel Drive (J492) Error
    Jan 2010
    chelmsford
    Hi Guys, i've got a 2004 A3 3.2 DSG Quattro with the following error on VCDS, the error started out as the Traction light coming on intermittantly but now it seems to be on 90% of the time.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No: 1K0 907 379 E
    Component: ESP ALLRAD MK60 0103
    Coding: 0021128
    Shop #: WSC 06435 000 00000
    VCID: 346C0054686179BC
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    004 -- No Signal/Communication
    Also shows:- 22-AWD -- Status: Sporadic communication error 1000
    Am i right in thinking this could be a bad connection on the haldex controller?? (or worse still a dead haldex ecu) Where is the haldex ecu (i.e connectors etc) located??
    Cheers in advance
    Neil
  2. Re: Control Module for All Wheel Drive (J492) Error
    Jan 2009
    towcester northants
    Quote Originally Posted by neilkaz View Post
    Coding: 0021128
    1 Fault Found:
    Cheers in advance
    Neil
    sounds like dead haldex ecu
    its located on right hand side of rear axle
    bit fiddly to do but can be done diy
  3. Re: Control Module for All Wheel Drive (J492) Error
    Jan 2010
    chelmsford
    Thanks for the reply and sorry i haven't got back on here sooner, although that was what i was dreading as they arent cheap. I got the car up on axle stands at the weekend and removed the Haldex ECU (easy job really, just a little fiddly). All the connections seem ok with no corrosion or dirt in\on them. Before i go and splash out on a new Haldex ECU is there anyway i can prove that the communication lines to the ECU are ok and that it isnt a problem somewhere in the loom?? Is it possible to test each of the pins with a multimeter (i.e look for voltage on the Can bus wires etc, i've seen a pinout diagram for the connector somewhere online)
  4. Re: Control Module for All Wheel Drive (J492) Error
    Jan 2009
    towcester northants
    never had one with wiring fault
    did have one which had been damaged on the underside of car
  5. Re: Control Module for All Wheel Drive (J492) Error
    130 Post(s)
    1972 Post(s)
    You can’t check them unless you have something like VAS PC and even that is inconclusive, with the fault code you have all you can do is fit a new unit and hope it cures it.
  1. Attention P1640: internal control Module MemoryCheck Sum error
    By Bazo in forum Touareg
    Last Post: 27-07-2010, 02:08 PM
  2. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  4. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
  5. Which control module do i have?
    By The Cambelt Kid in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-06-2009, 10:09 AM
