Thread: How to replace factory fitted rear parking sensor?
Results 1 to 10 of 11
  1. How to replace factory fitted rear parking sensor?
    Mar 2009
    London
    Morning all, I've got a long beep coming from the car when I put it in reverse so I'm guessing one or more of the factory fitted rear parking sensors needs replacing. I've looked at the threads here and it seems to be a quick and easy job but not found any instructions. Can anyone help?
    Also, where's the best place to get an official Audi replacement and will they need to be sprayed and lacquered or can I just provide the colour code of the paintjob? (misano red).
    I have VAG COM so will plug it in to get an error code, assuming there is none though, is it just a matter of cleaning the sensors? (car hasn't been washed for a while )
    Thanks in advance.
    04 A4 1.8
    T S-Line Multitronic (190bhp)
    Misano Red - Factory RS6 18" Alloys - Rear Folding Seats - Park Distance Control - Private Number Plate
  2. Re: How to replace factory fitted rear parking sensor?
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi Mr Horse, it's always a good idea to clean the car and sensors first ,but an easy way to check for the dud item, and this is how I did my check, is to select reverse with ingition on,,,,,,,,DO NOT START ENGINE,,, IGNITION ONLY ON.
    With the ignition only switched on and reverse selected you kneel down at the rear and place your ear to each sensor, the item or items which do not emit a sound, ( clicking/pulsing ) is/are failed
    I believe others on the forum have purchased a painted sensor and self fitted for less than £100
    Stuart
    1 1 0
  3. Re: How to replace factory fitted rear parking sensor?
    Southern County Softy
    20 Post(s)
    I replaced a rear on mine a couple of weeks ago, I had a thread running.
    VCDS the car to check which one is faulty, I brought a new one from Ebay, a guy in Poland has them, half the price of the dealer
    My local chipsaway man took the sensor, sprayed and laquered it for £20.
    I managed to remove mine without taking the bumper off, Using the A8tech "wiggle" method....
    http://cgi.ebay.co.uk/AUDI-PDC-PARKI...item4aaa96f705
    Check the part No. Offer him £35...
    A4 2.5 tdi QS (mapped)
  4. Re: How to replace factory fitted rear parking sensor?
    Mar 2009
    London
    Thanks for the links and replies folks, drove the car yest and the beeping had gone without me doing anything! Might be an intermittant fault so will plug in the VAG COM this weekend and check.
    04 A4 1.8
  5. Re: How to replace factory fitted rear parking sensor?
    Apr 2011
    fife scotland
    Hi a lot of good info on fittting of parking sensors but does anybody know if one sensor is out on the rear will it put the front sensors out aswell.
    cheers dodip
  6. Re: How to replace factory fitted rear parking sensor?
    Oct 2009
    10 Post(s)
    I don't know that one pal, but maybe the upset in the " parking system " from the rear sensor can upset the fronts, please enter the experts.
  7. Re: How to replace factory fitted rear parking sensor?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi dodip
    From me old greying memory Front & Rear Sensors are separate and should not effect each other.
    After several years being on a a good starting point is locate connector unplug a light spray of WD40 then plug connector block back together.
    Ensure all sensors out surfaces are clean
    Use VCD to read codes
  8. Re: How to replace factory fitted rear parking sensor?
    essex
    before replacing the sensor which isn't working, i'd be inclined to check the wiring to it or at the very least swap two sensors over to see if the problem moves. if it moves then the problem is likely to be sensor, if not its likely to be wiring or parking sensor control unit.
  9. Re: How to replace factory fitted rear parking sensor?
    Dec 2012
    Peterborough UK
    Hi I'm a newbie here so pls excuse my dumbness. I've got a N/S outer sensor gone, got the replacement ready to go, but I'm being a bit dense here I think. What exactly is the A8tech 'wiggle method' ? Or am I safer to remove the bumper?
    ps it's on a A6 C6 3.2 Quattro saloon
    Thanks in anticipation - David J
  10. Re: How to replace factory fitted rear parking sensor?
    46 Post(s)
    welcome to vwaf
    i suggest looking at these numerous threads and have a general search in the a6 c6 section
    Intermittent Parking Sensor Grief
    Parking system fault
    Parking sensor fault
    Parking Sensor size?
    Rear parking sensors
  1. Question how to replace rear abs sensor?
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-02-2011, 01:28 AM
  2. Rear Parking Sensor retro fitted to A4 Avant by A8 tech
    By cindacone in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-01-2011, 07:25 PM
  3. Please Help Factory Fitted Parking Sensor
    By JohnnieE in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-07-2010, 09:16 AM
  4. How to replace a parking sensor?
    By mangroa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2010, 01:51 PM
  5. Replies: 1
    Last Post: 31-07-2008, 06:33 AM
