Thread: Parking Aid Warning Chime (H15) Loation?
  1. Parking Aid Warning Chime (H15) Loation?
    west yorkshire
    My rear beep has gone... did a scan and threw the code:
    10543 Parking Aid Warning Chime (H15)
    have done a check and all rear bumper sensors are working fine through vcds so leaves the actual speaker it self?..
    any help on where it is, and part number, and a quick guide to remove and refit?
    thanks guys..
  2. Re: Parking Aid Warning Chime (H15) Loation?
    west yorkshire
    anyone, i have had a look under the rear shelf but cant see anything, just moved seats forward and un clipped the front of the shelf.. enough to remove the sound proof material, only thing tere is the light connection for boot..
  3. Re: Parking Aid Warning Chime (H15) Loation?
    Sep 2009
    Hamburg, Germany
    Should be rear left, accessed behind the side-cover.
    Stick a bit of tape over a sensor then switch on the parking sensors while you follow the sound in the back to find the speaker.
  4. Re: Parking Aid Warning Chime (H15) Loation?
    Sep 2015
    Largs UK
    I have the following fault through VCDS
    I own an Audi A6 2004 have not had it for long so have no idea where to start on this error
    any ideas on where to find the chime speaker or what to test as there is no beeps or any sound from it at all, so cant trace where it is
    I also noticed that one on the sensors on the rear bumper is slightly recessed compared to the rest, could this be a problem?
    1 Fault Found:
    01543 - Parking Aid Warning Chime (H15)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
  5. Re: Parking Aid Warning Chime (H15) Loation?
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    Three seconds on the interweb gets you this; Rear Parking Speaker / Buzzer Location - AudiWorld Forums
  1. Alhambra Parking Aid Module
    By smithg86 in forum Alhambra
    Last Post: 18-04-2010, 09:46 AM
  2. Parking Aid not working?
    By The-Stig in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-01-2010, 01:19 AM
  3. No rear parking aid on A4...but was advertised
    By druidt1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-09-2009, 10:51 AM
  4. Mmi Parking Aid Fault
    By abarth800 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-07-2009, 08:38 PM
  5. Audi Parking Aid
    By Robertarwel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-04-2008, 06:55 PM
