Thread: MMI restart problem
Results 1 to 10 of 12
  1. MMI constantly restarting (appears not to turn off?!)
    Nov 2006
    Hi guys,
    Got home last night and MMI working fine (after an 800 mile trip). Went out this afternoon and by the time I got to the bottom of the (short) drive the MMI had restarted. Didn't think much of it until it did it again after a few seconds and then kept doing it constantly with differing intervals.
    Turning the ignition off then back on had no effect.
    Being stumped and inquisitive I had a look in the boot and on the right hand side where the jack and some fuses are a little module (that seems to have been stuck on with mastic) was dangling down with a grey wire going to it. There was a red and a black wire that were obviously broken off where it had been hanging down and being thrown about.
    Only the grey wire remains connected
    Question is, what is this device and I am assuming that it is something to do with the MMI and causing the issues?
    Any help welcome as it is not actually my car (yet)!
    '07 A6 3.0 V6 Quattro S-Line Le Mans
    (@206k Aug 2018)
    '52 Passat TDI 130 Sport Avant - sold at 218k 2011
  2. Re: MMI constantly restarting (appears not to turn off?!)
    Nov 2006
    Just done an optical scan but I am none the wiser! Can anyone shed some light?
    Friday,06,May,2011,22:01:23:03080
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK ERROR
    07-Control Head ERROR ERROR
    0E-Media Player 1 OK OK
    1E-Media Player 2 ERROR ERROR
    77-Telephone OK ERROR
    47-Sound System OK OK
    56-Radio OK ERROR
    37-Navigation OK ERROR
    and here is the sorry looking scan. Lots of faults...
    Friday,06,May,2011,22:15:06:03080
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 3E 42 46 47 4F 52
    53 56 61 62 72 76 77
    VIN: WAUZZZ4Fxxxxxxxxx Mileage: 152140km/94535miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    3E-Media Player 4 -- Status: Not registered 0001
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H04--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 1E38C69DB031
    7 Faults Found:
    005495 - Right Engine Mount Solenoid Valve (N145): Open Circuit
    P1577 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    Date: 2011.05.06
    Time: 17:10:21
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 11.93 V
    Bin. Bits: 1
    Bin. Bits: 1
    Bin. Bits: 1
    006464 - Powertrain Databus: Missing Message from Control Module for Battery Monitoring
    P1940 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    (no units): 0.0
    005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
    P1699 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    Bin. Bits: 00001000
    005685 - Powertrain Data Bus: Missing Message from A/C Controller
    P1635 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.86 V
    Bin. Bits: 00001000
    005687 - Powertrain Data Bus: Missing Message from Electric Load Controller
    P1637 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    (no units): 3.0
    Voltage: 11.86 V
    Temperature: 29.7°C
    005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    (no units): 5.0
    Voltage: 11.93 V
    Temperature: 29.7°C
    005661 - Glowplug for Cylinder 4 (Q13): Open Circuit
    P161D - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    Date: 2011.05.06
    Time: 22:04:30
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.70 V
    Duty Cycle: 15.0 %
    Temperature: 33.3°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 F HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0030
    Revision: --H01--- Serial number: 4285013
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 2854E045E275
    5 Faults Found:
    049682 - Steering Column Control Module: No Communications
    U0212 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    RPM: 0 /min
    RPM: 0 /min
    (no units): 30.0
    (no units): 25.0
    Temperature: 46.0°C
    T.B. Angle: 0.0°
    049478 - No Communication with Diagnostic Gateway
    U0146 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    053258 - No Communications with Control Module for Access/Start Authorization
    U100A - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    049493 - No Communication with Instrument Cluster
    U0155 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    006231 - Load Signal: Error Message from ECU
    P1857 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    VCID: 66C8AE7D28E1
    3 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x0013
    Hex Value: 0x2991
    Hex Value: 0x00FF
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x002F
    Hex Value: 0x0491
    Hex Value: 0x00FF
    18265 - Load Signal: Error Message from ECU
    P1857 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x0028
    Hex Value: 0x0191
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
    Component: FBSAUDIC6 ELVSG H01 0030
    Revision: 31050601 Serial number: 10601200663266
    Coding: 0000019
    Shop #: WSC 02323 785 00200
    VCID: 244CF4759E5D
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    No fault code found.
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 731 R HW: 4E0 035 729
    Component: Interfacebox H43 3450
    Revision: 00000000 Serial number: 350AI077755510
    Coding: 0000002
    Shop #: WSC 02335 785 00200
    VCID: 31620D21D1AF
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000030204747
    Coding: 0001046
    VCID: 1C3CCC95A62D
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0011101
    VCID: 30640825DAA5
    Part No: 4F2 910 113 B
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH13 0090
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
    Part No SW: 4E0 035 785 HW: 4E0 035 785
    Component: SG ext.Player H09 0170
    Revision: 00000000
    VCID: E5CA297155E7
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0N4HNP
    Coding: 0013381
    VCID: 2952E541F97F
    1 Fault Found:
    004 - No Signal/Communication - Intermittent - MIL ON
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90026070190017
    Coding: 0112141
    VCID: E6C82E7DA8E1
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 981 F
    Component: KOMBIINSTR. M73 H20 0120
    Revision: 00000000 Serial number: 5HS30ZT17
    Coding: 2049448
    Shop #: WSC 00481 210 83225
    VCID: 234EF7699B53
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 13008071278459
    Coding: ECFE53C43B3104
    VCID: 2756E379EF6B
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 15
    Reset counter: 80
    Mileage: 152142 km
    Time Indication: 0
    Date: 2011.05.06
    Time: 22:07:40
    Address 1E: Media Player 2
    Cannot be reached
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 T HW: 4E0 919 887 L
    Component: MNS ECE H48 1030
    Revision: 00000000 Serial number: 364BI077635111
    VCID: 3E78261D10F1
    Address 3E: Media Player 4 Labels: None
    Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
    Component: MP3-Changer H44 0350
    Revision: 00044000 Serial number: AUZ5ZBG3150978
    Shop #: WSC 00000 000 00000
    VCID: 1834D0855215
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: b7D
    Coding: 0002682
    Shop #: WSC 02327 785 00200
    VCID: 2C5C1C55F68D
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01033580680000
    Coding: 0008689
    Shop #: WSC 00481 210 91547
    VCID: 2E58165DC091
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System
    Cannot be reached
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000375481
    Coding: 0001103
    VCID: DEB8069D70B1
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: StD
    Coding: 0002682
    VCID: 2C5C1C55F68D
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 02324 785 00200
    VCID: 2044F8658A45
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 120
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.87 V
    Count: 246
    00576 - Terminal 15
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 120
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.87 V
    Count: 41
    00456 - Control Module for Access and Start Control (J518)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 120
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.87 V
    Count: 247
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 394AL077730260
    Coding: 0000001
    VCID: 2E58165DC091
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000011450
    Shop #: WSC 00481 210 88137
    VCID: 234EF7699B53
    Part No: 4F0 915 105 D
    Component: von VA0 2701301052
    Coding: 344630393135313035442056413032373031333031303532
    Shop #: WSC 00000 384 00290
    1 Fault Found:
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 152142 km
    Time Indication: 0
    Date: 2011.05.06
    Time: 22:07:02
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0002090
    VCID: 2E58165DC091
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0002090
    VCID: 2E58165DC091
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
    Component: Parkhilfe 4-Kan H09 0060
    Revision: 00H09000 Serial number: 06230702904364
    Coding: 0001106
    Shop #: WSC 131071 1023 2097151
    VCID: 2756E379EF6B
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 L HW: 4E0 862 335
    Component: Handyvorb2 H20 1120
    Revision: 00000000 Serial number: 00000005155307
    Coding: 0010920
    VCID: 2B5E1F49F383
    (@206k Aug 2018)
    46 Post(s)
    Try clearing them and see if any re-appear first of all.
    Could you post a bigger picture of the part and what's on the other side?
  4. Re: MMI constantly restarting (appears not to turn off?!)
    Nov 2006
    Cleared them at about 17:00 today and there are more this time (22:00 ish). Didn't look at the optical bus though then but tested it at 22:00, cleared and tested again and it was the same. Haven't driven it since this afternoon though.
    I will post a bigger picture tomorrow as it is chucking it down with rain at the moment.
    The module that fell off has/had three wires going into it (red, black and grey) and a connector block coming out of it with a loom which is taped to the box itself so only apears to have power with the grey wire being the output - for what I don't know. Looks a bit of an installation mess to me and not sure if that is the cause of the fault or it has been like it for a while. Can't believe Audi would just mastic something on!
    Got to give it back to my mate tomorrow and haven't told him it is broken yet Looks like an MMI issue with something but don't know what and not obvious to me from the codes.
    Always been looked after by the same dealer since new, and only one owner so not messed with - he is not that type of owner. Maybe I am just unlucky to have whatever it was break when I was evaluating it for purchase
    (@206k Aug 2018)
  5. Re: MMI constantly restarting (appears not to turn off?!)
    May 2007
    knee deep in clunge
    14 Post(s)
    its a tracker and probably fitted by a third party for the dealer
    mmi fault is this -------------------------------------------------------------------------------
    Cannot be reached THIS IS AUDI MUSIC INTERFACE
    and this
    Cannot be reached THIS IS THE AMPLIFIER
    one of the above has crashed causing optical break in the circuit
    also some coding problems in gateway please confirm if you have ami fitted/retro fitted
  6. Re: MMI restart problem
    Nov 2006
    Has MMI high fitted as standard. Bose sound too. One multichanger and mmi cable in glove box (which had my ipod connected, plus amp satnav in boot.
    I have tried the reset with buttons and through vagcom (just enough time before it restarts) but no improvement.
    cheers
    (@206k Aug 2018)
  7. Re: MMI restart problem
    Nov 2006
    Looks like it might be a tracker then. Don't think he knew he had one.
    Is it worth disconnecting the battery for a while or will it need some codes on start up? Don't want to break it more than it is already
    (@206k Aug 2018)
  8. Re: MMI restart problem
    May 2007
    knee deep in clunge
    14 Post(s)
    it already broke and you need to bridge the optical circuit at either the amp or ami to allow the most circuit to complete and eliminate the failed control unit
    you need a most repeater to do this and this simply takes the place on the most loop of the suspected failed control unit to re establish the optical ring
    Dealer visit beckons I'm afraid
    Please post your findings after repair
  9. Re: MMI restart problem
    Nov 2006
    Maybe the long drive was too much for it - or my taste in music made it loose the will to live.
    Will let you know when it is back from the dealers. Let's hope it is the cheapest part that has failed!
    Thanks all.
    (@206k Aug 2018)
  10. Re: MMI restart problem
    Nov 2006
    Managed to complete an optical test without everything booting and I only got media player 2 erroring on both electrical and optical. What is media player2?
    Went out for a drive to the shops and the red dash airbag light came on as well. I am sure this is all down to the can controller or media fault.
    Cleared all the faults so see what happens between now and dealers.
    (@206k Aug 2018)
  1. MMI problem
    By mark connor in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-02-2011, 01:36 PM
  2. MMI problem?
    By young bill in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 23-05-2010, 08:51 AM
  3. Q7 MMI - iphone problem
    By SiQ7 in forum In Car Entertainment
    Last Post: 22-02-2010, 09:59 PM
  4. 3.2 Quattro DSG 04 - Cold-restart problem
    By mickyblue38 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-11-2009, 11:48 PM
  5. A6 MMI problem!
    By RGM10 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-11-2008, 08:19 PM
