Thread: MK4 Golf Temperature Gauge Sat Just Above 90 Degrees
  1. MK4 Golf Temperature Gauge Sat Just Above 90 Degrees
    Mar 2010
    Bude, England
    Hi there please help...
    I have a 52 plate Mk4 Golf 1.4 petrol and recently noticed the temperature gauge on my dashboard sits just above the 90 degree mark when its warmed up. It used to sit dead on the 90 mark.
    I was told it could be the thermostat so i had that replaced but still it sits only slightly above the 90 degree mark at about 95 degrees.
    PLEASE HELP!!
  2. Re: MK4 Golf Temperature Gauge Sat Just Above 90 Degrees
    Southampton, UK.
    If you get plugged in with VAG-COM, you can see what the engine temperature reading actually is. I think Crasher once said that in the Mk4, the gauge shows 90C but the real temperature can be say +- 10C (something like that). Basically, the gauge doesn't budge away from 90C unless the engine does start to get too hot or cold.
    I guess it could be one of these:
    - the coolant temperature sender is giving a false reading (too high) so it sends the gauge up;
    - the engine is actually getting too hot;
    - the gauge is displaying incorrectly.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: MK4 Golf Temperature Gauge Sat Just Above 90 Degrees
    Mar 2010
    Bude, England
    Thank you for the reply after the engine had properly cooled down and i went to use it again from cold and the car seemed to reset itself, all power cut out including all dials on the dashboard, clock, miles, everything just turned off when i turned the ignition. I got out and locked and unlocked the car again and it seemed to be fine and the temperature reading now sits dead on 90 again which proves it was the thermostat that was faulty. BUT the car now continues to cut out and reset on random occasions when i turn on the ignition. What could this be???? PLEASE HELP
  4. Re: MK4 Golf Temperature Gauge Sat Just Above 90 Degrees
    Southampton, UK.
    Quote Originally Posted by ARW-360 View Post
    ...the temperature reading now sits dead on 90 again which proves it was the thermostat that was faulty.
    Does it? What you do have is probably a faulty relay or a poor earth somewhere.
  1. Replies: 0
    Last Post: 03-07-2009, 07:48 PM
  2. Temperature Gauge
    By Brian Rouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-02-2008, 05:54 PM
  3. Temperature Gauge Showing 90 when Cold
    By dave78 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-12-2007, 12:40 PM
  4. Golf MK4 OEM Sat Nav
    By Skidmark in forum Golf MK4 - 1999 - 2004
    Last Post: 21-02-2007, 01:12 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
