Thread: Hard to start and slight hesitation
Results 1 to 9 of 9
  1. Question Hard to start and slight hesitation
    Oct 2010
    Stone, Bedfordshire
    OK, I have a 2007 A3 Quattro. It has FSH and has just been serviced at 88000 miles. When I go to start the car in the morning if I just turn the key without touching the accelerator peddle the car will often fire and stop or fire and run really rough for a few seconds. Once the car has been started you can then restart just using the key no problem. Along side this there is an annoying hesitation at low RPM (1-1.5k). It feels like a fuel starvation problem. I have checked the fuel filter and it has defiantly been changed on the service. Something is wrong and I don't know what to do. I have Vagcom but unsure what to check for help..... PLEASE HELP, it's driving me mad.......
  2. Re: Hard to start and slight hesitation
    Oct 2010
    Stone, Bedfordshire
    Well I'm gutted no one can help. My issue seems to be slightly worse now.... When the car is left for a few days and I try to start it the engine spins over and nothing happens. I have to keep on turning the engine over, pumping the accelerator, almost untill the battery dies!!!
    I have Vag-Com but unfortunatly no idea what to log. I am thinking it's a fuel supply problem as even the next day I have to put my foot on the accelerator to aid starting, otherwise it can take a real long (over 10 seconds) crank to get going!!!!
    PLEASE PLEASE HELP........
    46 Post(s)
    As you said you have vagcom, connect it and switch on the ignition and start a fault code scan and post the results if anything appears then post it up here.
  4. Re: Hard to start and slight hesitation
    Oct 2010
    Stone, Bedfordshire
    Hi Chris, thanks for your reply. The first thing I did was to check for faults using vagcom. Nothing to report there though. Everything is showing with no errors.
    I am hoping someone will tell me to monitor certain blocks in vagcom to check fuel pressures etc.
    Fingers crossed.
  5. Re: Hard to start and slight hesitation
    Aug 2010
    west mids
    is your car petrol or diesel?? and is the car sometimes lumpy on idle??
    Oct 2010
    Stone, Bedfordshire
    Hi, sorry, I forgot to mention my car is diesel. It's slightly lumpy on tickover if it has been hard to start. Once you have revved her slightly the tick over is Ok. Can it be some fuel pressure that drops over time? I'm not sure hoe the fuel system works on this type of car!
    I use VCDS and will help nice folk.....
  7. Re: Hard to start and slight hesitation
    May 2007
    knee deep in clunge
    14 Post(s)
    insufficient cranking rpm caused by weak battery or worn starter motor
    insufficient residual fuel pressure caused by leak off or defective tandem pump
    excess soot in fuel caused by blow pass at the injectors
    incorrect fuel or coolant reading
    pre supply pump in the tank defective or air being drawn in
  8. Re: Hard to start and slight hesitation
    Oct 2010
    Stone, Bedfordshire
    Crikey!! Thanks a8 tech.
    I am drawn towards the residual fuel pressure or pre supply pump due to the fact it gets worse the longer the car is not used.
    Can you give me any guidance on how to check for problems with these two units?
    Sorry for all the questions. I've had enough experiance with buying expensive parts already....
    Many thanks.
  9. Re: Hard to start and slight hesitation
    May 2007
    knee deep in clunge
    14 Post(s)
    try to fit a clear fuel pipe from the fuel filter to the tandem pump in port and observe the fuel flow when cranking
    or clamp the return hose the evening before then see if it starts better
    for slow cranking boost start it and see if it makes any difference
    try these basic tests before waving a multimeter at it
  1. 2.5 TDI AYM engine Hard starting now wont start
    By westfield1962 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2013, 10:25 AM
  2. Replies: 0
    Last Post: 13-02-2011, 08:57 PM
  3. slight mettalic noise from gearbox?
    By zalek in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-12-2010, 11:18 PM
  4. Please Help Edition 30 - Cold Start & Idling
    By AnSGTI in forum Golf MK5 - 2004 - 2009
    Last Post: 09-08-2010, 02:28 PM
  5. A6 2.0 tdi cold / not start - engine hesitation
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-09-2009, 02:44 AM
